Old 05-20-2019, 07:32 PM
RV-4 RV-4 is offline
Question G696 Battery
Hello ALL
Will anyone of you here on VAF know of a good source to purchase a Garmin 696's battery other than Garmin??
I just purchased a 696 for a friend and the battery is no longer holding a charge..
Bruno
rv4@videotron.ca
Old 05-20-2019, 08:49 PM
DaleB's Avatar
DaleB DaleB is offline
No aftermarket sources, but they're not difficult to rebuild. I've done a couple of them. If you can solder, it's fairly simple.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 05-20-2019, 11:18 PM
XPPilot XPPilot is offline
Default Garmin 696 battery
If you do little research you can find instructions how to rebuild 696 battery.
http://www.vansairforce.com/communit...ht=696+battery
Old 05-21-2019, 09:44 AM
William Slaughter's Avatar
William Slaughter William Slaughter is offline
BatteriesAmerica.com has a cell pack pre-configured for this. Just search garmin 696 on their site. Just bought one last month, good service and delivery
William Slaughter
Houston, TX
RV-8QB
Old 03-05-2020, 06:16 PM
cwilkins cwilkins is offline
Default Direct Replacement?
Is this a direct replacement or is there something you need to add? I noticed there are some sort of electronics attached to the batteries in the 696.
Craig A. Wilkins
RV-8 N898R - Bought Flying
RV-7A N36HS - Bought Flying (sold)
Cherokee Six N5259S (Sold)
Old 03-06-2020, 08:30 AM
This is definitely a "some assembly required" project, but no additional stuff needs to be purchased. Once you cut the plastic case open, you can compare the existing install and the new cell pack to see what gets reused. This project requires some solid soldering skills.
William Slaughter
Houston, TX
RV-8QB
