Old 04-21-2007, 10:08 PM
avi8tor50 avi8tor50 is offline
Default Panel warning lights and dimmer
Looking for simple, inexpensive, panel warning lights. Have 5/16" holes. I've seen what B&C has. Any other suggestions?
Also need a panel dimmer. Looking for something simple but one that won't get too hot.
Thank you one and all.
Peter K
RV-9A QB
Panel wiring
Old 04-22-2007, 06:43 AM
N941WR's Avatar
N941WR N941WR is offline
Peter,
Do the lights have to be 5/16"? If not, go to Radio Shack, they have some very nice and very small LED lights.
As for the dimmer, check with Radomir, he bought a nice one from some place. (I bought mine from Dale who bought it years ago from Electric Bob and never installed it.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-22-2007, 06:55 AM
briand's Avatar
briand briand is offline
I was thinking LED's behind a semi-transparent square cover, labeled with black-over-clear Dymo labels. Anyone know where to get some blank covers? The cover could be clear with colored LEDs or color with white LEDs. I'm sure its already been done.
Old 04-22-2007, 10:48 AM
RatMan RatMan is offline
Paul Dye has a really good write up about how he built his but I can't find it for you. Maybe Paul can help find it.
John Ratliff
N898R
RV-8
Saucier MS
Old 04-22-2007, 11:01 AM
mgomez's Avatar
mgomez mgomez is offline
Default Try NKK
NKK makes some LED annunciators. Try www.nkkswitches.com. They're not too bright, though.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 04-22-2007, 01:36 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Try here
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-22-2007, 07:11 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default What about this dimmer?
Has any one use the Dimmer from Perihelion Designs?
http://www.periheliondesign.com/egpavr.htm
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 04-23-2007, 06:43 AM
randylervold's Avatar
randylervold randylervold is offline
moderator
I also used the standard aircraft lights that B&C sells. I like them because they use the same bulbs that Whelen post lights use so you can swap in-flight if you have a bulb go bad. I used them in my RV-8 also and found them fine except they are too bright at night. Recently I came across some LED lights at SteinAir after the fact, they might be just right. Scroll about half way down this page... http://www.steinair.com/lights.htm
Can anyone give us a pirep on them?
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse in box
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 04-23-2007, 09:27 AM
scard's Avatar
scard scard is offline
I have five of them in my plane.
Scott Card
CMW E-Lift
