05-18-2019, 09:55 AM
Engine vibration
Getting more time in the new aircraft. It has a stock 260HP IO540-C4B5. The prop is a MTV9B 3 blade. The engine is turbine smooth at 2650 RPM but has a noticeable vibration as you bring the prop back below 2600 RPM. Prop has about 870 hours total time and 50 since a complete overhual. The motor is at 870 since overhual. I would like to try and get the engine smooth across the normal operating range. Is a dynamic balance the best first step or are there other things to check first? All blades seem tight in the hub.
George
05-18-2019, 12:38 PM
search for prop clocking. Several have had good success with an alternate prop clocking arrangement on the 540 and I plan to do that on my C4B5. You will need to move the prop bushings around to do that though.
Larry
05-18-2019, 01:48 PM
Larry
Not sure you will have the same effect clocking as with a 2 blade.
I would suggest that you start with a Dynamic balance.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
05-18-2019, 02:10 PM
Moderator, Asst. Line Boy
I agree with Walt. Beyond that recommendation, do your EGTs stay consistent across all cylinders when you throttle back? Why I ask: If a dynamic balance doesn?t fix it, and if one of your EGTs drops off during throttle-back, you might explore a stuck valve.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
05-18-2019, 04:13 PM
I will check the EGT?s carefully next time out. The vibration starts with a RPM reduction. Power does not seem to be a factor.
05-20-2019, 11:17 AM
Flew today and EGT?s are consistent. If RPM is pulled before power there is vibration. If I do a small power reduction prior to the RPM reduction things are fine. Dynamic balance is in work but not sure it will help.
George
