04-21-2007, 04:42 PM
OX Systems-where to mount
I'm looking for suggestions and pictures of where's the best place to locate the OX tank.
Which size cylinder has worked best for you.
These cylinders are about the same price, 6, 9, 13 CU Foot.
My preference is the 13 which is 4 3/8 x 19".
The smaller 6 CUFt fits well between the seats on the flap housing but the capacity is small.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
04-21-2007, 04:56 PM
I have the 13 cu ft bottle mounted behind the passenger seat in my -6.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-21-2007, 05:02 PM
One location
On the -9s, -7s and-6s one easy option is to mount the bottle vertically behind the seats in the center of the fuselage.
A top mount can bolted to the back of the seat back support cross-piece (F-605F on the-6) and a base support made and attached to the hold down screws for the central tunnel cover.
If you do this, you can put the regulator directly on the bottle, and plug in the masks/cannulas directly into the regulator. The bottle on/off is also accessible in flight, which is a plus.
CG issues should not be too bad, and a glider type 22 cu ft bottle should fit here.
Oxygen bottle sizes are here... along with regulators....
http://www.wingsandwheels.com/page35.htm
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
04-21-2007, 05:03 PM
Hi Mel.
Do you have it in the baggage compartment or under & behind the seat under the seat back rail?
Does it interfere with any baggage compartment loading?
I had thought about putting it there and build a pvc pipe holder with a bungy cord to contain it.
1190+ hours
2019 Donation Paid
04-21-2007, 06:39 PM
It's vertical in the front starboard corner of the baggage compartment. First I tried to put it in the center but could not reach it in flight. It came just to my elbow. On the right hand side, I can reach it and it doesn't interfere with baggage loading.
04-21-2007, 08:00 PM
O2 bottle
I have mine mounted probably in the same place as Mel....vertically front right side of baggage compartment where I can reach it. Unless you can fill it cheaply, a 22 cu ft may be a better option (short stubby cylinder). It will last longer and probably the same cost to fill as a small one.
04-23-2007, 10:25 AM
Mel - Ron
Any pictures to look at for the mounting brackets/hardware?
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
04-23-2007, 10:39 AM
Actually, I have my bottle out right now. But it won't take a few minutes to go out and install it. Give me your email and I'll send pics this afternoon.
04-23-2007, 11:00 AM
Thanks Mel.
kent.d.byerley{AT}tek{DOT}com
Looking forward to seeing your pics.
Kent
Kent Byerley
Canby, Or
04-23-2007, 11:14 AM
Check you e-mail. I just sent pic. Any questions...972-784-7544
