Old 05-16-2019, 08:54 AM
DanH's Avatar
DanH DanH is offline
Default Angle Valve Cyl#1 Intake Pipe
Plenty of past debate about cold air intakes, but not much actual data.
I'd like to measure the intake air temperature just prior to arrival at the cylinder head. Doing so would require drilling a hole in the intake pipe, and possibly welding a bung or fitting. My 390 has a nice set of chromed pipes; I don't want to drill or weld on them.
So, anyone have a rusty old intake pipe gathering dust? Looking for cyl #1, angle valve with the tuned plenum sump, Lycoming # 78741, same as most IO360 angle valve models.
Temperature is also required for understanding intake pipe wave activity with this sump.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-16-2019, 12:21 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Dan, why not use the primer port in the head? That's pretty close to the gasket interface where the intake tube mounts, and with the engine running should be plenty of gas flow to get reasonably close to the same temp as in the pipe.
You could use a Swagelok compression fitting in the port with a thermocouple inserted to whatever depth you want. You can find cheap TC readers on ebay.
Also, you could tap a hole (1/8 NPT) into the back of the plenum/sump and put a probe there. That's what I did years ago to tap off the manifold pressure for my panel gauge and electronic ignition. Could even do that while installed. Just remove the rear intake pipes so that you can clean out the chips from drilling/threading.
Heinrich
Old 05-16-2019, 12:56 PM
868RM 868RM is online now
Default Pipe
Dan I have either a number 1 or 2 intake pipe for a 390 will look later today
Old 05-16-2019, 01:36 PM
larosta larosta is offline
Dan,
If you can slip an extra gasket in place you might be able to position a thermocouple across the diameter and centered in the airflow. The extra gasket would electrically insulate and provide a seal around the thermoouple wires. We have used this technique to measure temperatures of in fluid flows where we did not want to make permanent modifications to a system in the past.
- larosta
Old 05-16-2019, 02:43 PM
DanH's Avatar
Good idea, but already have a pressure tap screwed into the primer port.
Hey, there's a trick worth remembering!
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-16-2019, 03:36 PM
TShort TShort is offline
I don?t have one, but am interested to see the data from this testing..
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 05-16-2019, 05:02 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Dan, how are you determining crank or cam position?
Ross Farnham, Calgary, Alberta
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 450.6 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://www.sdsefi.com/aircraft.html
https://www.youtube.com/channel/UCiy...g2GvQfelECCGoQ
Old 05-16-2019, 07:34 PM
DanH's Avatar
Spark signal to a second channel...the 23 BTDC marker.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-16-2019, 10:01 PM
Bdalporto Bdalporto is offline
I've always wondered if cold air intakes worked. It seems that the time the air spends in the hot part of the sump wouldn't be long enough for it to absorb much heat.
Brian Dal Porto
RV-7 Tipper
IO-360A3B6D
Whirl Wind 200RV
Dynon Skyview Touch
Old 05-17-2019, 09:02 AM
airguy's Avatar
airguy airguy is offline
Depends greatly on whether you are talking to someone from Engineering, or someone from Marketing.
Garden City, TX VAF 2022 dues paid
N16GN flying 950 hrs and counting on 91E10; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
