Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
  #21
Old 06-26-2019, 08:30 AM
Raymo's Avatar
Raymo Raymo is offline
Originally Posted by cojaken View Post
Thought ... initial adjusting via EICAD should not be a repetitive thing. Rather than installing a Dsub9 in the cockpit, I?m thinking of making up a harness to be connected directly to the Pmag temporarily when needed.
Comments?
You'll want to leave the harness connected. Mine are just tie wrapped under the cowling for easy access through the oil door. I've adjusted mine a few times for Adv Shift and Max Adv and happy with Adv shift = 0, Max Adv = 33.6 (or was it 32.2?). I wrote the settings down on my laptop at the hangar for future reference.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
