Old 05-13-2019, 09:32 AM
jacoby jacoby is offline
Default Adjustable squeezer ram doesn't fit?
I bought an adjustable ram from ATS (the 214CAR) and it doesn't fit. It also doesn't look like the picture on their site; this one looks more like the AE274 listed except it has a different anti-rotation design.
The base of the ram is 0.630" wide but the opening in my riveter is 0.615" wide near the yoke holders and tapers down to about 0.525" wide. I can probably grind off the extra 0.020" or so in width and then round over the corners to make it fit but is this typical?
My squeezer is a genuine CP-214 but it's of unknown vintage.
Old 05-13-2019, 09:28 PM
NotMuchofaStall NotMuchofaStall is offline
Default Similar issue
I got my adjustable set holder from Aircraft Spruce, and I had a similar issue where it would bind up because it was just a little bit too big. I filed mine down about 0.020? total on the sides to get it to slide freely. A few minutes on the Scotchbrite wheel did the trick, and having a pneumatic squeezer has saved me all kinds of time and trouble.
Will, building an RV-9A
Horizontal stabilizer in progress
Donated September 2019
Old 05-14-2019, 11:29 AM
Ryano Ryano is offline
I had the same problem with mine and employed the same solutions mentioned above.
Practice Kit completed 2/19/2017
Tooling up for -7 empennage build.(100% tooled 1/31/2018)!
Orphaned -7 empennage kit purchased! 9/15/2017
-7/8 Rudder 25% complete.
2019 Donation paid...
Old 05-14-2019, 11:32 AM
I ended up grinding the base down to 9/16" and leaving the little triangular anti-rotation tab. Seems to work; it goes up and down freely. I haven't set any rivets or dimples with it yet though.
