Old 04-21-2007, 11:23 AM
Xilo_xatron Xilo_xatron is offline
Default Rudder Trailing Edge Bowing
Greetings,
Should a bow of 2/32" on the rudder trailing edge of an RV-7 be cause for concern? I checked the edge while I was riveting, but apparently did'nt catch it as it was bowing. I'm good at drilling out rivets! Any help would be greatly appreciated.
Thanks!
Old 04-21-2007, 12:00 PM
asu4me asu4me is offline
The allowable number I recall from the folks at Van's is <.100" bow, so you should be ok.
Jerry Kosirog
Mesa, AZ.
RV-7A (Wings)
Old 04-21-2007, 02:09 PM
Thanks for the response....what flying qualities can one expect from a rudder that is not straight? I don't want to be too anal about it, however if I can fix the problem now, I would rather address it.
Old 04-21-2007, 07:04 PM
I can't speak from facts since my -7 isn't yet flying, but I can't imagine that the amount of bow that you mention would make a noticeable difference.
Can someone else comment on this?
Jerry Kosirog
Mesa, AZ
RV-7A Flying Phase 1
N855GK
rv74me@yahoo.com
Old 04-21-2007, 08:20 PM
fodrv7's Avatar
fodrv7 fodrv7 is offline
Default Light riveting
I managed to get mine straight by riveting alternative sides as I went, only riveting every 3rd or 4th rivet.
I can't see why you can't apply a little pressure with the rivet gun (Back riveting) to take the bow out. It is all solid aluminium so it can't be squashed, but just might squezze it enough to reomve the bow.
Pete.
Peter James.
Australia Down Under.
Old 04-21-2007, 09:48 PM
TJoyner TJoyner is offline
I don't think it's a big deal. I'd just move on, and I bet after a while you won't even notice it...
Tom Joyner/ F70 (French Valley, CA)
Old 04-21-2007, 11:25 PM
jcoloccia jcoloccia is offline
You're well within Van's specs which means it's as straight as it needs to be to fly as intended. It also means that making it straighter won't make any appreciable change in handling. So you can't really make it better but you CAN make it a whole lot worse. Something to ponder...
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
Old 04-22-2007, 08:40 AM
morlino's Avatar
morlino morlino is offline
Default did you follow the procedure in the manual?
Just out of curiosity, did you use the method with the aluminum angle and tank sealant in the manual? If so was it straight before you riveted?
I followed the book and mine came out straight but I felt like it was a lot of extra time and work. I think it still would have come out straight if I had just riveted the pieces together. My practice kit was straight without the angle and the proseal, although that is considerable shorter than the rudder.
Oh well, I guess the tank sealant was good practice working with tank sealant for when I get my wings.
FWIW, drilling out that many rivets is probably not worth the trouble.
Old 04-22-2007, 01:00 PM
Robert M's Avatar
Robert M Robert M is offline
I followed the instructions but I used regular 30 minute epoxy. It came out pretty darned straight but I know that using the regular epoxy will cause a catostrophic failure from the vibration of the engine when I do my first engine start.
"Pilots: Looking down on people since 1903"
(author unknown)
RV-9, N556RM, O-320, Dual PMags, Catto 3 blade.
FLYING since 2018
Mosquito XEL ready for flight
