Go Back   VAF Forums > Model Specific > RV-9/9A
  #11
Old 05-11-2019, 02:47 AM
Hornet2008 Hornet2008 is offline
Thanks Mark I will give this a try and report back. My flaps are not flush either, I set them up with a digital level on initial rigging.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 05-11-2019, 07:18 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Originally Posted by Hornet2008 View Post
I have rigged my ailerons with the tooling holes and bellcrank locking plate during initial rigging and checked at last condition inspection and still get a roll to the left in flight. Could I eliminate this roll by adjusting flaps? Thanks in advance.
Flaps are but one item that can create a heavy wing - but easy to fix. Most overlooked (and fairly common) are low/high/in/out aileron brackets.
Recommend stepping back and spending some time to systematically rig your ship. Here is a post on how: http://www.vansairforce.com/communit...=165907&page=2
Don?t forget the wheel pants and gear leg fairings.
Carl
Old 05-11-2019, 09:08 AM
mark960 mark960 is offline
Default Results
OK, so I adjusted the ailerons up so they are now even with the flaps. Sighting down the top wing surface, they appear to be reflexed by about a half a degree. Flew it this morning and I have picked up 3-5 knots. Not sure of the exact speed increase, but definitely an improvement.
Mark Klepper
N1075 FA81 - Ft Myers, Buckingham Field
Van's RV9A Slider
Old 05-15-2019, 07:51 AM
N942R N942R is offline
Default Flap and aileron rigging
Flaps should be up against the bottom of fuselage; both the same. Ailerons should line up with flaps with elevators neutral and with a slight upward pull on both ailerons to take slack out... Tips should line up with the ailerons.
Heavy wing correction is another issue and is corrected in other ways, not by trying to raise or lower a flap or ailerons.
Old 05-15-2019, 10:24 AM
RV7Guy's Avatar
RV7Guy RV7Guy is offline
Default Flaps first
You really want to get this as accurate as possible. It is amazing that squeezing an aileron an imperceptible amount can make a difference. Imagine misaligned surfaces!!
Generally, get the flaps rigged first. The bottom skin flush against the fuselage. This is a solid baseline. Next the ailerons. Work and adjust the rod end bearing until you have perfect alignment. It may take a half turn at a time.
I like to clamp the aileron to the flap. This makes adjusting the rod ends easy. Adjust until the bolt will go through the rod end and the bell crank. Make sure the stick stay in the same spot!!! Don't forget to tighten the jam nut!!
Finally time to bring the tips into compliance. The alignment holes will generally be pretty close from my experience. Adjust the flanges of the tip to get the alignment correct.
Now work on the aileron to tip gap. Fun with fiberglass!!
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
Old 05-15-2019, 10:56 AM
rvbuilder2002's Avatar
Good advice (since the photos the OP originally posted indicated that the flaps and the ailerons are mis-rigged), but, this advice is only valid if it has been confirmed that the flaps and ailerons do not have an twist in them.
If they do, aligning all of the ends to each other may not be the best procedure.
Scott McDaniels
Hubbard, Oregon
