Old 05-10-2019, 08:23 AM
Bavafa Bavafa is offline
Default A nightmarish thought regarding cowl pins
I love the clean look on my top cowl which uses piano hinge and they go in/out with relative ease but I wonder if they would ever cease in place for any reason as that would be a nightmare.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 05-10-2019, 08:34 AM
BobTurner BobTurner is online now
Did you mean ?seize??
Everytime I R & R those pins I put some Boelube (the solid, waxy kind) on the pins. So far, no problems.
Old 05-10-2019, 08:35 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
The short answer is no.
I also add a drop of oil on each pin to make it easier.
Carl
Old 05-10-2019, 08:42 AM
bkervaski's Avatar
bkervaski bkervaski is offline
They actually get more loose as you install/remove them. Initially they are a pain in the backside requiring generous amounts of Boelube. After about 10-20 times they loosen up. I was on the fence about them but love them now.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 05-10-2019, 09:53 AM
Saville's Avatar
Saville Saville is offline
what version of Boelube do you guys use?
The medium paste: 70307-02-001 - 1 ?
soft paste: 70302-12-001 - 1 ?
Or some other?
thanks
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 05-10-2019, 10:01 AM
flightlogic's Avatar
Default lube
I always clean and lube mine each time they are removed. I sometimes use Kroil or another lube. Doesn't really matter much, but they bind less and go back in smoothly. The last inch or so, I grab them with a large needle nose and adjust the final fit.
Cheers.
"Kindness is never a bad plan."
exemption option waived. Donation appropriate.
Old 05-10-2019, 10:11 AM
Forgive my spelling, I had mean seize, which might just cause to cease my RV ownership
I use soft paste Boelube on my pins and strongly recommend to avoid dry spray lube that is often used on table saw, etc. I used it during the build as well as with my old RV and it actually made removing very difficult. Boelube makes it very easy.
Mehrdad
Dues paid
Old 05-10-2019, 10:24 AM
Or some other?
thanks
70200-13 is what I use, from ACS.
