Proseal tip
I found that I ran out of proseal after finishing the tanks and doing most of the firewall sealing. I did not need another full quart and the 3.5 ounce would be enough over time.
Tip: buy the 3.5 ounce and use a razor blade to cut off the plunger with the black portion. Then remove the white portion from main tube and store in a plastic container. Do the same with the black portion. Now you can use when ever you want.
I seem to recall that I lost a bit of each doing thins, but not a lot.
Ken Stockman
Midland, MI
EAA Chapter 1093 member
FaceBook Page: Ken's RV-14
RV-14a (serial number 140073)
N73XP
Plane at hangar and the wings ON.
