Old 04-30-2019, 07:44 AM
Jvon811's Avatar
Jvon811 Jvon811 is offline
Default RV-4 Pitch Servo Mounting Question?!
Just purchased the pitch and roll servos from GRT for my RV-4 and was curious how others have mounted pitch servos in their airplanes.
I bought a flying airplane which had a Navaid Devices AP before I rebuild the panel so there are already provisions for mounting the roll servo. But where to put the pitch servo stumps me. I'm assuming it'll go in the tailcone, behind the baggage area. And how exactly it will interact with the elevator push rod stumps me too.
Any Suggestions?! Thank you very much.
-Justin
RV-4 N249P
O-320, Dual P-Mags, Warnke Prop, GRT Sport EX
Old 04-30-2019, 05:28 PM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Pitch servo
Download the Garmin 28 instructions. Pretty logical.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 04-30-2019, 09:34 PM
Jvon811's Avatar
I guess I'm confused or maybe I should have been clearer.
Does the Garmin GSA 28 install manual have pictures of how a pitch servo is installed in a "typical" RV-4? I found the manual online and couldn't see anything -4 specific unless I missed it.
Does anyone have pictures of their installations so I might get or steal some ideas?
-Justin
RV-4 N249P
Old 04-30-2019, 10:23 PM
SMRacer SMRacer is offline
http://grtavionics.com//media/Autopi...tup-071718.pdf
Go to page 5 for a nice picture of a GRT pitch servo install in an RV4.
GRT will sell servo install kits.
Jim
Leesburg, VA (KJYO)
RV4 N444JT (sold)
RV8 N37PK
Old 04-30-2019, 11:21 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Dynon instructions
The Dynon instructions and kit are very good, and will work with the GRT servos.
I used a combination of all the instructions to understand what was happening, and I believe it worked out fine.
http://www.rv8.ch/autopilot-pitch-servo-installation/
You will need to drill out some rivets - if you are not comfortable doing that, I strongly recommend you get a good local builder to help you, or use an airframe A&P you trust. This is not a good place to practice this for the first time.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 05-01-2019, 06:26 AM
RogerG RogerG is offline
Trutrak was helpful on one install we did on the RV-4. See this link: https://cdn.shopify.com/s/files/1/21...16506169632008
Roger Graham
Lubbock TX
RV-4 Under Construction
VAF Dues Paid 2018-2019
Old 05-01-2019, 06:33 PM
Jvon811's Avatar
Excellent! Thank you everybody. This website is truly great for knowledge that would otherwise take me awhile to find out on my own. Although... I'm a little embarrassed when SMRacer points out my exact install manual had a pic of an RV-4 install... I bought the servos and have been looking at them and brainstorming/conceptualizing and haven't bothered to look at the manual yet!!
-Justin
RV-4 N249P
