Old 04-29-2019, 03:42 PM
galt1074 galt1074 is offline
Default F779 and tailwheel spring
I'm having some fit issues in the tail and I know some other folks have had some similar issues.
The problem I'm having is with the spring itself. The weld at the front doesn't appear to be at the correct angle. When I try to install the aft-most bulkhead (F712 I think) it obviously requires the tails spring to be half-way in the mouse hole for the bulkhead to be installed. When the tail spring is in this position, there's a gap (probably 3/16" at least) at the top of the forward flange of the tail spring where it attaches to F711.
Anyone seen this and do I just add some shims?
I'm also having a heck of a time getting all the holes to line up but I think I just need to remove more material and make the hole bigger for the spring to pass through.
https://photos.google.com/share/AF1Q...VkeWdJMWdiamd3
Greg LeCrone
Lakenheath, UK
Builder 74755
RV-7: Empannage complet, working on aft fuselage
Old 04-29-2019, 04:27 PM
Wunderon's Avatar
Wunderon Wunderon is offline
on my 8 I did shim that location approx .032” or so.
These shims were called out in my instructions.
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 04-30-2019, 02:27 PM
Default big gap
Dave,
Thank you for your reply.
My concern is that my gap is 3/16" and growing as I remove material to get F712 to seat properly over the tail spring. If it were .032" that would be easily acceptable but this seems ridiculous. Either I'm doing something wrong or this part is bad.
Anyone?
Greg LeCrone
Lakenheath, UK
Builder 74755
Old 05-02-2019, 03:11 PM
SeanB's Avatar
SeanB SeanB is offline
Greg,
Did you measure the location for the front bolt holes on the bulkhead? I don't see any marks. I'm wondering if the steel part may just need pushed down some more, making it less of an angle. But, this is where you will also need to be careful with edge distance on all parts for the bolt holes.
SEAN BLAIR V7
Colorado Springs, CO
https://eaabuilderslog.org/?blprojec...&listcat=&sid=
2021 VAF SUPPORTER
Old 05-02-2019, 04:07 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
On my -8, Vans recommended using shims or a spacer to fill the gap using the tail spring flange as a pattern. My gap was quite big from memory, maybe 1/8 or so. I?ll see if I can dig up a photo.
Paid up - Sep 2021
Old 05-02-2019, 04:54 PM
Maxrate Maxrate is offline
Greg, welcome to the club. Most including myself had to shim due to the angles being slightly off. Mike Bullock has a great section in his builders log and here is a link to where I had to wrestle with the aft tail spring bulkhead. Good luck. You?ll eventually get it.
http://www.mykitlog.com/users/displa...=250369&row=28
http://rvplane.com/?categoryid=4&dayid=372
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2021 Donation gladly paid..
Old 05-03-2019, 07:05 AM
AndyWW AndyWW is offline
I had problems in this area and ended up having the WD-409 cut and re-welded. One of the faces was not parallel to the other one and my inspector wasn't comfortable with shims of different thicknesses that could have introduced point loads. After the repair everything was nice and parallel and I just used one 0.032" shim at the forward end of the weldment.
Andy @ EGLM/EGTB
RV-6 (Shared, Bought Flying)
Building RV-7 #74424
Riveting fuselage
Donated 2021
Old 05-04-2019, 03:24 AM
Default Maybe bad part
Andy,
If the angles are supposed to be parallel then I'm quite certain I have a bad part. I'll call Van's and talk it over.
Thank you everyone for the replies. I skipped the wings so I don't know about them but the beginning of the fuselage with the way some parts don't fit and how vague the instructions can be has been pretty aggravating. I'm sure I'll figure it out and it will be fun again.
Greg LeCrone
Lakenheath, UK
Builder 74755
Old 05-04-2019, 11:34 AM
Default "fixed" it
So there's nothing wrong with the part, there's nothing wrong with the skins, and there's nothing wrong with the way I was preparing everything except for missing some clecos.
I went ahead and put together the whole aft-fuselage and discovered my main issue was the angle of the F711/712 bulkheads because I hadn't cleco'd the top holes in the F779 skin where it joins with the top of the curve at the bottom of the bulkheads. This meant my bulkheads weren't at the proper angle and my tail spring was at the proper angle but everything looked off by a lot.
Now I have what appears to be all the standard problems with that part of the fuselage, which makes me feel better.
Thank you so much for all the replies.
Greg LeCrone
Lakenheath, UK
Builder 74755
