Old 04-28-2019, 10:23 PM
lndwarrior lndwarrior is offline
Default Damaged thread at engine case oil return fitting
Engine is an O-235. I finally traced an oil leak to a damaged thread inside the case at the oil return fitting.
Is the best solution to run a tap down the thread? If so, any tips on doing this? Since it's inside the engine case I'm concerned about screwing this up.
Any suggestions you have would be appreciated.
TIA
Gary
Old 04-29-2019, 09:42 AM
guccidude1 guccidude1 is offline
Running a tap to clean the threads is what I would do. Do it slowly and coat the tap with copious amount of grease to catch any metal filings. Go in a couple of turns remove, clean the grease off. recoat, and go in again. Wrap the male threads liberally with teflon tape and tighten. If it will not tighten, the only alternative I know of is helicoil. Get your local mechanic to do the job. Good luck, Dan from Reno
Old 04-29-2019, 10:38 AM
engineerorange engineerorange is offline
Originally Posted by BillL View Post
heli-coil for an NPT thread designed to seal?? Maybe this recommendation should be reconsidered.
Minute - - -sorry
My case had one helicoil installed by crankcase services in a boogered oil return hole at overhaul. A little thread sealant and it is fine. NPT threads don?t seal without some sealant.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
Old 04-29-2019, 10:42 AM
BillL BillL is offline
Good to hear. I deleted my post then a little research turned up some claims but "with sealant" was not very definitive. Your first hand knowledge is reassuring.
Bill
RV-7
Old 04-29-2019, 10:44 AM
maniago's Avatar
maniago maniago is offline
Teflon tape? Really? Maybe if you are super super experienced in its application.
Otherwise, Locktite 567 is bullet proof and idiot proof....and personally, I resemble that remark.....
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y
