Old 04-29-2019, 10:41 AM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
There have been a couple of posts highlighting the fact that the IFR equipment lists are specific to standard category aircraft. But realistically, does anyone have OLs that permit instrument flight without referencing 91.205(d)?
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Donated dollars - 2020
Old 04-29-2019, 10:50 AM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
Originally Posted by titanhank View Post
I have a d180 based panel. I would recommend a used garmin 400w. It gives all the ifr enroute and approach capabilities i will ever need. Can be bought for $3500-$4000 or possiblity the new gtn-175. This also gives you a waas ouput for adsb.
A 420w would also give you a second comm radio.
I currently have one for sale on that other big selling site....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-29-2019, 11:26 AM
The FARs, for EAB in IFR (assuming the usual op limits), are very generous. No mention of backups, dual power sources, or heated pitots. But that just means, just like many other choices, they?ve left it up to your judgement as to what is really needed for a reasonable level of safety. BTW, some EFIS boxes -Dynon and Garmin among them-require airspeed or gps data to reach an attitude solution. That may influence your heated/not heated pitot decision.
Old 04-29-2019, 12:36 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Well I just got back from the still useless North Dallas FSDO ( at least they’re consistent in being useless ). I got my replacement airworthiness certificate due to a registration number change and they didn’t include that I could fly if I have the equipment as per 91.205. He told me that he can’t change ops limits when replacing the aw certificate. Of course he showed me a highlighted piece of paper he printed but I showed him that had to do with replacements after a person losing his aw certificate and that wasn’t my case.
So he told me if I have everything needed for IFR flight then someone from their office has to come out to my plane and see it then they’ll add that to my op limitations. Anyone heard of this before ?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 04-29-2019, 01:52 PM
Originally Posted by Pilot135pd View Post
Well I just got back from the still useless North Dallas FSDO ( at least they?re consistent in being useless ). I got my replacement airworthiness certificate due to a registration number change and they didn?t include that I could fly if I have the equipment as per 91.205. He told me that he can?t change ops limits when replacing the aw certificate. Of course he showed me a highlighted piece of paper he printed but I showed him that had to do with replacements after a person losing his aw certificate and that wasn?t my case.
So he told me if I have everything needed for IFR flight then someone from their office has to come out to my plane and see it then they?ll add that to my op limitations. Anyone heard of this before ?
Are you saying your original Op Limits did not have the phrase ?VFR only unless equipped as per 91.205...?? If so they must be pretty old; and he?s right, there are separate hoops to jump thru to get them changed. But if they did have this phrase, and the new ones don?t, then the FSDO screwed up in changing them; call them back.
Old 04-29-2019, 03:50 PM
Pilot135pd's Avatar
No, my original ops limits say that if equipped I can fly at night and IFR but he chose to not include that even though I clearly told him about it. Now I'm grounded from flying my plane at night too !
I'm telling you, this North Dallas FSDO needs adult supervision quickly !!!
I'm preparing an email right now with copies of everything to send to Washington, I'm done dealing with these inept employees.
Old 04-29-2019, 04:22 PM
rv7charlie rv7charlie is offline
Instead of pushing up, why not let someone in real authority push down? You're an EAA member, right? Call 'em up, tell 'em your problem. They'll contact FAA HQ, and HQ will 'educate' the FSDO.
Old 04-29-2019, 04:38 PM
Pilot135pd's Avatar
Oh we're way past that. This has been going on for over 9 months. It's already in Washington, I just needed to update them on today's fiasco. Email has gone out. Regarding EAA and AOPA I think that's the next step, thanks for the suggestion !
Old 04-29-2019, 05:54 PM
Walt's Avatar
Walt Walt is offline
Why not just give Mel Asbury a call, pay him a couple of bucks and let him handle it. He's the Guru for this kind of stuff.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 04-29-2019, 06:33 PM
Pilot135pd's Avatar
Because we have an office of the FAA and they’re supposed to provide a service.
