Old 04-29-2019, 06:59 AM
RV8iator's Avatar
RV8iator RV8iator is offline
Originally Posted by FlyingBanker View Post
You didn?t mention having a heated pitot, but I believe you would need that for legal IFR.
Not required for legal IFR.
Jerry "Widget" Morris
RV 8, N8JL, 3,000+ hours on my 8.
VAF #818
Saint Simons Island, GA. KSSI
PIF 2008, 2009, 2010, 2011,2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019, 2020
I just wish I could afford to live the way I do
Old 04-29-2019, 07:28 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Originally Posted by HBpilot View Post
On the other hand, a VOR/ILS solution might just do it. As I mentioned, I only want to be able to file IFR for enroute. I am not interested to do low ceiling approaches in a single engine. I'd rather drive on those days.
If you just want to legally "get into the system" and nothing else, then the VAL-429 VOR/ILS solution is the least expensive way to go. BUT unless you will never fly within Tampa, Orlando, Miami, Ft. Lauderdale, Jacksonville, Sarasota, Ft. Myers or any other "Rule Airspace" you really should consider an IFR solution that includes ADS-B out. "Pay me now, or pay me later."
Just my 2 cents.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 04-29-2019, 08:18 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
For standard aircraft, a heated pitot tube is required if it's going to be flown IFR as per Part 23 however some may argue it doesn’t apply to experimental aircraft and only Part 91.205 applies.
Part 91.205 lists the gyros and radios required in addition to the VFR equipment needed and doesn’t mention heated pitot tubes but also mentions standard category airplanes. Now the good stuff, what does your Ops Limits say regarding IFR flight?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 04-29-2019, 08:28 AM
RV6_flyer's Avatar
(4) Part 91.205 DOESN'T LIST a heated pitot tube as a necessary element required for IFR flight. It only lists the instrument panel gyros, instrumentation, and radios required in addition to the VFR equipment needed.
The Operating Limitations define what is required for IFR and or night flight. Some Operating Limitations have the Limitation of DAY VFR ONLY.
Operating Limitations require that we meet requirements of 91.205 for night and or IFR operations.
Part 125 only applies to aircraft with 20 or more passengers. Part 23 only applies to Standard Category aircraft. Again, Operating Limitations have what requirements that our EXPERIMENTAL aircraft are required to meet. Latest version of FAA Order 8130.2 has the FAA Requirements for an amateur built experimental airworthiness certificate.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-29-2019, 08:36 AM
Pilot135pd's Avatar
Just my 2 cents.
So I?m considering an ADS-B product that?s going to cost me $1300 then I add a VAL-429 for another $1800 for a total of $3100. What would you recommend that?s cheaper than that?
Old 04-29-2019, 08:43 AM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
I was not the builder on that RV so I cannot do the work
As others have mentioned, you can do the work yourself. I'm in an almost identical situation myself. I bought my RV as well, and while it was already minimally equipped for IFR, I'm working on improving its capabilities. I've found it to be an uphill battle learning everything required, but I've enjoyed the journey so far. I've done lots of reading, studying, and planning, and I'm almost ready to start cutting and stripping my first wires!
One thing that I haven't seen mentioned yet is to check your Operating Limitations. Most that I have seen have language like, "After completion of phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with ? 91.205, this aircraft is to be operated under VFR, day only." If yours lacks the underlined text (or something very similar), other folk smarter than me will have to advise what your options are for issuing new OLs.
EAA has an article that would answer most of your questions.
https://www.eaa.org/eaa/aircraft-bui...ifr-operations
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Donated dollars - 2020
Last edited by thompsonbr87 : 04-29-2019 at 08:55 AM. Reason: Strikethough - other folks posting while I was typing. Edit 2: apparently strikethrough code doesn't work here...
Old 04-29-2019, 09:09 AM
FlyingBanker's Avatar
FlyingBanker FlyingBanker is offline
Apparently there is some room for debate on this, but I can tell you in my own personal risk management profile, there is no way I want to be in any visible moisture without a heated pitot. So for my VFR to IFR conversion, that will be a non-negotiable include (I?ll add AOA while I?m at it).
Jim Bedsole
N62MG - RV-6A "Promises" - bought flying
Dues Paid
Old 04-29-2019, 09:38 AM
maniago's Avatar
maniago maniago is offline
Not yet mentioned, but you also gotta comply with marker lights etc for IFR/night flight......
The VAL unit other guys have mentions is slick, tho I'd personally go with a used SL30 and then youve got an extra panel radio to boot.....would cost more tho.
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Old 04-29-2019, 09:53 AM
titanhank's Avatar
titanhank titanhank is offline
I have a d180 based panel. I would recommend a used garmin 400w. It gives all the ifr enroute and approach capabilities i will ever need. Can be bought for $3500-$4000 or possiblity the new gtn-175. This also gives you a waas ouput for adsb. I also have a d10a as a secondary attitude indicator and a trutrack vizion 385 autopilot that shoots beautiful coupled approaches. D10a used for under $1000 and the autopilot is $1800. The autopilot has its own ahrs system that can fly even if both dynon’s die which is unlikely since both have backup batteries installed. To be basic ifr, all you need is a single radio and appropriate nav radios for the intended route. A single vor system will work, but is probably not the level of equipment most pilots will accept. This entire panel cost $13k.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
Old 04-29-2019, 09:58 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Not actually required per the FARs.... but recommended
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
