Go Back   VAF Forums > Model Specific > RV-14
Old 04-28-2019, 05:44 PM
Rteem Rteem is offline
Unhappy Elevator Mismatch (Drilling Mistake)
So, looking for some sanity or help from the community.
Part of mounting the elevators requires having them both at neutral, and using a guide block / clamp to make sure that they are drilled both perpendicular and even to each other.
Unfortunately, the clamp I chose to use didn't quite hold against the will of a new #16 drill bit to wander.
I now have a hole that is off by a slight amount on the left elevator, and the result is that the elevators are about 1/4 inch off at the foremost section where the weights are.
I'm looking for recommendations on how to recover, here's some things I've considered:
1. Rebuild one of the elevators - I simply don't see how without massive work I could replace just the horn because the skins won't peel back nicely anymore now that they are rolled.
2. Fill the hole with weld, and redrill the elevator horn
3. Set neutral to split the difference (so one rides 1/8 low and the other 1/8 high)
Any help or suggestions would be GREATLY appreciated... pictures here:
https://photos.app.goo.gl/ZHBQydUfhDd6ot5K6
Old 04-28-2019, 05:59 PM
Girraf Girraf is offline
I saw photos just a few weeks ago where someone corrected a similar mistake by flowing metal into the hole with an appropriate welding tool, dressing smooth, and re-drilling. That's the route I would take first. Accepting a split deflection on the elevators would be a nonstarter in my opinion.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 04-28-2019, 06:16 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Did the same thing, had a welder fill it, sand, paint and re-drill ... perfect now ... consider that a practice run.
Seems like everybody knows a welder, it took all of 10 minutes.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-28-2019, 06:19 PM
wirejock's Avatar
wirejock wirejock is offline
Default Weld the hole
I dorked one of mine. Take it to a good TIG welder. Mine was welded and so smooth if not for the paint, I wouldn't gave spotted the weld. I redrilled and applied some matching paint.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-28-2019, 06:42 PM
M McGraw's Avatar
M McGraw M McGraw is offline
Default Been there
I welded in a small piece of metal the thickness of a washer and re-drilled. Your not the first. Weld and move on, it will be okay.
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 750+
2021 Dues Paid
The Dues Paid note is a reminder for me
Old 04-28-2019, 09:27 PM
Tankerpilot75's Avatar
Tankerpilot75 Tankerpilot75 is offline
When I purchased my RV7A from the builder he had mis-drilled the elevator horn so poorly that there was almost a 1 inch difference between the left and right side elevators. To compensate for this difference it appeared he mis-rigged the ailerons. Bottom line: the aircraft wanted to roll upside down the faster it flew.
The fix for this was to weld closed the old holes and drill new ones correctly. Had to re-rig the ailerons and balance the elevator. But after the corrections were made the aircraft flew wonderfully. No issues since and it’s been four years.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Dual GRT Horizon EX with ARINC, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level & auto-trim, Tosten 6 button Military Grips, FlightBox wired to EX, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
Old 04-28-2019, 11:11 PM
Bavafa Bavafa is offline
Welding a piece as a doubler is a great idea but consider welding the piece on the outer side since you might run into issues with the spacing to the center bearing.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 04-29-2019, 06:44 AM
BillL BillL is offline
Default Nothing structurally wrong with a patch, but . . .
A good TIG welder can weld inside the hole, a little grinding and it will be flat => recommended.
Bill
RV-7
Old 04-29-2019, 09:51 PM
jcarne's Avatar
jcarne jcarne is offline
Yep, have it welded and redo. I had to do it on my canopy frame where the nylon slider is.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 04-29-2019, 11:35 PM
eliasj7 eliasj7 is offline
I goofed up mine also. I googled welders in my area and found a custom car shop that had good reviews for TIG welding. I showed up with elevator in hand and the first thing the guy said was "Is that off one of those RV planes? Some mismatch drill issue? I've welded a few of these over the last couple of years". -Made me feel a little better.
