  #61
Old 04-30-2019, 08:37 AM
rvbuilder2002's Avatar
I find these types of threads amusing......
The FAR's and (some) operating limitations require the pilot to identify his aircraft as experimental on first contact with a control tower. It is not required for any other ATC communication (approach control, en-route center, etc.).
In this thread we have had a lot of "what I do".... and that "no one has ever said anything"..... much of it contrary to the rules.
It doesn't matter if the rule makes sense or not (a lot of them don't). It is still a rule that applies to everyone and I think it is in appropriate to promote the idea that because someone has personally decided that it doesn't apply to them, that everyone else should operate that way as well.
As with anything else in life, each person has to make their own decision, but be clear in doing so that the requirement applies to every experimental class aircraft, whether you think it should or not.
Scott McDaniels
Hubbard, Oregon
Old 04-30-2019, 08:50 AM
NewbRVator NewbRVator is offline
Probably doesn?t matter unless you?re in busy controlled airspace.
Clearly?...!!!?- no pun intended, there?s a little confusion regarding proper behavior on all sides. I think if I am sandwiched between ?Heavies? landing in busy airspace where it?s hard to get a word in edgewise on the radio I would definitely prefer ATC to know exactly what type of aircraft I am flying.
But yeah amusing topic
20 dues paid member since 2018
RV6A
Old 04-30-2019, 09:16 AM
rocketman1988 rocketman1988 is offline
Default Yep
"...I find these types of threads amusing......
As with anything else in life, each person has to make their own decision, but be clear in doing so that the requirement applies to every experimental class aircraft, whether you think it should or not..."
Well said.
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 04-30-2019, 09:25 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
I agree +10,000%
I shouldn't care what the rest of you do, but just a few "bad apples" can give the rest of us that follow the requirements a bad reputation.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 04-30-2019, 09:34 AM
F1R F1R is offline
Default ADSB info?
Im just curious about what ADSB will bring to the table in this discussion.
After January 1,2020 will ATC have enough information to know exactly what type / model & N reg. they are dealing with ?
Old 04-30-2019, 10:30 AM
kmbusse kmbusse is offline
As a controller in Canada, I couldn't care less what you call yourself with your registration. Experimental, Vans, RV, romeo victor7, RV7, all good in Calgary VTA. If I need more, I'll ask. But if you tell me you are an RV-14, expect some questions and a quick chat about where I'm at with my build.
Kerry
Old 04-30-2019, 10:38 AM
DanH's Avatar
DanH DanH is online now
Scott, Bob, Galin...you use "experimental" in your initial call to ground, before taxi? Or do you wait until your "Ready on XX" call?
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-30-2019, 10:48 AM
I do.
Home base airport tower has said they prefer to have you identified as such when calling ground because the ground controller hands off the info to the local controller (when they are busy enough that they have both positioned man'ed).
BTW... they are totally by the book here (casual about nothing) and do identify an experimental as such, to any other traffic they are communicating to about said aircraft.
Scott McDaniels
Hubbard, Oregon
Old 04-30-2019, 10:49 AM
GalinHdz's Avatar
FWIW I use "Experimental" for all my transmissions. Since I am not that smart I gotta keep it simple.
Galin
CP-ASEL-AMEL-IR
2020 Donation made
Old 04-30-2019, 11:03 AM
Saville's Avatar
Saville Saville is offline
I do. First call only (if they respond).
Flying RV-8 N880BC
2019 Dues - happily paid.
