Old 04-24-2019, 03:28 PM
ShortSnorter ShortSnorter is offline
Default Starburst (Not the candy)
Has anyone seen this around the shop head of a rivet? Does it have something to do with anodized surface?
Disclaimer: As with most photos, the details look more exaggerated. In other words this is difficult to see unless the light hits it just right.
Ryan
RV-14 In-Progress
Build Site
Old 04-24-2019, 04:09 PM
wirejock's Avatar
wirejock wirejock is offline
Default Starburst
Yes, and I assume yes since I've only seen it on anodized surfaces.
Also, next time you set a rivet with the squeezer, watch and see if you spot a little puff of smoke. I would love to know what that one is.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 01/01/2021, plus a little extra.
Empennage, wings, fuse, finishing kit, now FWF
Disclaimer
Old 04-24-2019, 04:18 PM
Girraf Girraf is online now
I immediately noticed the puff of smoke when I started using my squeezer. I'd love to hear an explanation for that!
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 04-24-2019, 05:30 PM
1001001's Avatar
1001001 1001001 is offline
Don't breathe it in. That's the chromate coating coming off the rivet.
To comply with AN Standards, the manufacturers must put a protective surface coating on the rivets. This may be zinc chromate, metal spray, or an anodized finish.
The protective coating on a rivet is identified by its color. A rivet coated with zinc chromate is yellow, an anodized surface is pearl gray, and the metal sprayed rivet is identified by a silvery gray color. If a situation arises in which a protective coating must be applied on the job, paint the rivet with zinc chromate before it is used and again after it is driven.
https://monroeaerospace.com/informational-rivets.php
Old 04-24-2019, 06:29 PM
scrollF4's Avatar
scrollF4 scrollF4 is online now
Moderator, Asst. Line Boy
The puff of smoke is intense momentary heat created by the molecular friction generated by the rivet squeeze.
Seriously.
The radial lines are gravity lines radiating from the worm hole singularity you created when you squeezed that rivet. See INTERSTELLAR. Congratulations. You squeezed the perfect rivet.
(Not seriously. I have no freakin’ clue.)
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 04-24-2019, 06:30 PM
jcarne's Avatar
jcarne jcarne is offline
Yep, I always try to exhale if I'm squeezing with my face close to a rivet, I figured that stuff can't be good in the lungs.
Jereme Carne
PPL
RV-7A Flying as of 03/2021
Exempt but gladly paying!
Old 04-24-2019, 08:30 PM
Seriously.
(Not seriously. I have no freakin? clue.)
For 2 nanoseconds I thought I had something to brag about.
Ryan
RV-14 In-Progress
Build Site
Old 04-24-2019, 09:58 PM
wirejock's Avatar
Default Smoke
That's probably why I no longer require a squeezer to set rivets. I just pinch them between my fingers. Weird superpower I know.
Larry Larson
Estes Park, CO
Disclaimer
Old 04-25-2019, 05:28 AM
N804RV's Avatar
N804RV N804RV is offline
I got this when I set the first couple of rivets on the webs to the fuselage center section halves. After that, I put the manufactured heads to the anodized part and It didn't happen anymore.
Ken W.
Mount Vernon, WA
2021 VAF Supporter
Old 04-25-2019, 06:57 AM
I considered that until I reread the note below in the plans. Nothing in the plans jumps out out me as the reasoning, but as always you know Van's put it there for a reason.
Ryan
RV-14 In-Progress
Build Site
