Old 04-23-2019, 05:46 PM
sglynn's Avatar
sglynn sglynn is offline
Default RPM stay out zone
I have the YIO-360-M1B and Hartzell CS Prop that you buy thru Vans on my 7A. Am I suppose to have a stay-out zone on RPMs between 2150 - 2350 where continuous use is not advised? Or a "yellow" stay out zone?
I've seen this in other POH's but I can't verify it is necessary. If true is this a attribute of the engine/prop combo? Or use of this engine/prop on an RV7A?
Thanks for clarifications.
Steve Lynn
Built RV-7A
Flying It
Anacortes, WA
www.mykitlog.com/sglynn
Old 04-23-2019, 05:55 PM
BillL BillL is offline
Steve, the RPM zone changes with product changes, so it would be best to get this from Hartzell for your (prop) serial number and engine model. Compression ratio, timing etc can make a difference.
Bill
RV-7
Old 04-23-2019, 06:12 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Originally Posted by BillL View Post
Steve, the RPM zone changes with product changes, so it would be best to get this from Hartzell for your serial number and engine model. Compression ratio, timing etc can make a difference.
Bill is correct. It's an RPM range where the Hartzell engineers have noted excessive vibration. However, it can change from other factors.
For example, I have the same engine and prop as you. Based on the engine, prop, and hub model and serial numbers, the Hartzell folks gave me the same avoidance range.
Now, however, with the addition of two PMags, they want me to avoid 2000-2250 for extended operations. I folded these into my POH and adjusted the green and yellow bands in my Skyview EMS.
Give the Hartzell folks a call: They'll send you a great email reply. I printed mine and filed it in my engine's and prop's documentation.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 04-23-2019, 06:19 PM
Walt's Avatar
Walt Walt is offline
Check the application guide on the Hartzell website:
http://hartzellprop.com//services/pr...ication-guide/
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
RV7A built 2004, 2000+ hrs, New Titan IO-370, Bendix Mags
Old 04-23-2019, 06:27 PM
RV6_flyer's Avatar
What blades are on your Hartzell prop? The TCDS should have most of the info you are looking for.
Different blades have different RPM yellow zones.
The old F7666 blades have a yellow zone to avoid continuous operation
between 2000 and 2350 RPM.
The F7496 blade also have some limitations. I think there was a time limit at 2700 RPM only for takeoff plus some manifold restrictions in addition to other limitations.
The F7497 blade was the most desirable blade but I do not remember what if any limitations existed.
Most of the Hartzell metal props had limits when using higher compression pistons and electronic ignition.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-24-2019, 07:57 AM
rvsxer rvsxer is offline
Originally Posted by RV6_flyer View Post
The old F7666 blades have a yellow zone to avoid continuous operation between 2000 and 2350 RPM.
That should be 2000 and 2250 RPM. I have those blades and 180 HP.
Mike Hilger
RV-6 N207AM w/G3X, 1,800 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
Old 04-24-2019, 10:22 AM
sglynn's Avatar
Default Vans IO360-M1B and Hartzel
Conclusion:
I did submit inquiry to Hartzell and received quick email reply say, "No restrictions for the 180HP YIO360-M1B with HC-C2YR-1BFP prop on my RV. I
And the Application Manual 159 (shared on this thread earlier) verifies this to be true also. So great, for those who bought "standard" IO360 engine and CS prop combo from Vans there are no RPM restrictions.
Thanks for the help.
Steve Lynn
Built RV-7A
Flying It
Anacortes, WA
Old 04-25-2019, 08:09 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Are there any restrictions on Catto props?
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 22, 2021
