Each RV6 is a bit different here. There are a few issues you want to be aware of as you size the pushrod, assuming we are taking about the steel one from the control weldment to the bellcrank.
Weldment hitting the rear spar web at full aft stick deflection. Some manipulation of the weldment (grinding) where the rod end attaches may be necessary. Keep your edge distances!
The push rod hitting the flange of the cutout under the baggage bulkhead. (Trimming for clearance is usually required).
The “hex” rod that ties the two stick weldments together can rub on the push rod as you move the stick side to side with stick at full deflection.
All of these are affected by the length of the pushrod.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
