Old 04-18-2007, 02:54 PM
jacksel jacksel is offline
Smile Pitot- static lines
My pitot tube in my RV-6 is soft aluminum. However, I need to mate this line to nylon-type fittings in some new instruments. Is there a recommended way to do this?
Old 04-18-2007, 03:02 PM
jlfernan's Avatar
jlfernan jlfernan is offline
I used a plumbing fitting availabe at most hardware stores. It's used to connect plastic water lines like for a fridge with an ice maker. They're just a plastic version of an AN fitting. They are designed to hold high water pressure so they will work fine in a low pressure(static) enviroment. Go the the link below and you can see what I used. Mine I got at the home Depot's Aviation Dept.
http://www.waterfiltersonline.com/de...=Fitting_union
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 04-19-2007, 07:09 AM
Steve Steve is offline
Slip a short length of 1/4" i.d. vinyl tube over the aluminum and poly tube ends. Add spring clamps as req'd.
1/4" i.d. fuel hose works too.
Steve
