Old 04-22-2019, 10:18 AM
rsr3 rsr3 is offline
Default Nut rotation tell-tale paint
Can anybody tell me what I should be searching for to find some of that coloured paint / wax that is applied to nuts and bolts to indicate any unwanted rotation after they've been torqued?
Thanks!
Old 04-22-2019, 10:20 AM
Brantel's Avatar
Brantel Brantel is offline
It is typically called Torque Seal.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-22-2019, 10:22 AM
Spot on - thanks very much!
Old 04-22-2019, 10:53 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I pickup up some of the CrossCheck at SnF. Seems much better than TorqueSeal. Foil tube instead of plastic. The TorqueSeal brand has always dried out very quickly for me, sometimes before I can even use it.
Mike W
Venice, FL
N164WM
N184P reserved (RV-8QB)
Old 04-22-2019, 11:04 AM
vlittle's Avatar
vlittle vlittle is offline
Since this stuff is considered hazmat for shipping, I had to find an acceptable substitute.
My suggestion is that you dress up in your finest duds and go to the cosmetics counter at your local drugstore. Ask for fingernail polish, preferabley in a bright color.
Alternatively, ask your wife. Your color selection may be more limited.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
Part of EAA award-winning OnSpeed team
The VV in huVVer.tech
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 04-22-2019, 11:14 AM
wirejock's Avatar
wirejock wirejock is offline
Default Nail polish
V
+1. I have four grand daughters. They gave me all their old polish. Most of it was wild colors. I have a 10 year supply. Helps when they get thick. Almost the same consistency as torque seal.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Rick_A's Avatar
Rick_A Rick_A is offline
Torque seal (or a similar product) is useful to tell a fastener was torques at a point in time, it does not guarantee that the fastener is properly torqued after it has been in service for a period of time. It is very useful while building.
When doing an inspection (like an annual), I always check that fasteners are tight with a wrench - regardless of whether or not the "torque seal" looks good. There have been many times when the torque seal looks good but the fastner needs to be snugged up a bit.
I don't always use a torque wrench when checking tightness but as I've learned, a visual check alone is not a real check.
Rick Aronow,
Flying 7A Slider;
RV-12 SOLD
Jacksonville, FL
Old 04-22-2019, 11:18 AM
Nail varnish.. Good shout - thanks everyone. My nails - er, I mean my nuts - will be looking fabulous in no time!
Old 04-22-2019, 11:37 AM
rv7charlie rv7charlie is offline
I'm not going there....
Old 04-22-2019, 12:07 PM
DHeal DHeal is offline
In a pinch, that white paint used to cover up typing errors (e.g., old, thickened Sno-Pake or Liquid Paper) works well as an indicator that you have properly addressed a particular nut/bolt. I have found that such markings' "torque indicating" value diminishes over time. It is best used as an indication (at one point in time) that you have completed the appropriate operations on that specific nut/bolt.
ps -- I know, I know....who still has a typewriter.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 1,080+ hours (as of Oct 2021)!
VAF donation through June 2022.
