Old 04-19-2019, 02:00 PM
Maxrate Maxrate is offline
Default Empennage fairing hardware
Vans has you tap several places along the longeron for a No.6 screw. In the pic you can see where I have the fairing attached at the bottom. Without a nutplate to really grip the screw and hold it in place is there any alternative ideas to keeping those screws secure? I thought about a low strength Loctite, or some similar product. The final hardware will be a flush stainless screw with a tinnerman washer.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 04-19-2019, 02:41 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
It's a non-issue in my experience. Properly tapped, and reasonably torqued, the screws will stay put just fine. I've never had one back out at all between condition inspections, 7 years running.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 04-19-2019, 02:48 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
And even if you lose one or two screws, it's a so-what. Non-structural piece held in place by air loads...
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 04-19-2019, 03:09 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
I have always use nutplates instead of relying on a #6 threaded hole in the aluminum longeron.
Carl
Old 04-19-2019, 03:43 PM
N941WR's Avatar
N941WR N941WR is offline
There is no issue with adding #6 nutplates on the inside, if you want.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-19-2019, 04:27 PM
Auburntsts's Avatar
A bit tangential as your main question has been answered, but on the topic of hardware I swapped all of my #6 Phillips heads for torx heads as it?s ridiculously easy to strip the Phillips heads out.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-19-2019, 04:32 PM
The problem with adding nut plates inside at this point is that the skin is already on. Would anyone care to share how they accomplished this. Thanks
Mark Malone, RV7
N442MM reserved
Old 04-19-2019, 05:17 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
A no. 8 screw will be more reliable and less prone to stripping if one gets heavy handed.
Jerry Esquenazi
RV-8 N84JE
Old 04-19-2019, 05:34 PM
rv7charlie rv7charlie is offline
Simple. A spelunker partner.
Old 04-19-2019, 06:31 PM
BillL BillL is offline
Just use ACR style driver bits from APEX and you won't strip them.
Bill
RV-7
Lord Kelvin:
