Old 04-17-2019, 02:16 AM
Roarks's Avatar
Roarks Roarks is offline
Default RV8 N1986 Mesa, Arizona
Howdy!
Well today is the start. After dithering on a decision, having the plans preview book for 6 years I called today and ordered the tail feathers.
It's been a long time coming. I had just finished my Aerospace engineering degree, I finally got my private, then got distracted with helicopters for a while. Thought I would consider an RV... Took the eaa sheetmetal class... It was good but I thought there should be more so I got my A&P certificate. Now I teach sheetmetal at the part 147 mechanic school!
Should be an interesting ride. Which I could fast forward to see the end of this thread!
Old 04-29-2019, 03:08 PM
Roarks's Avatar
Finally. Not sure why I had such issue trying to upload pics.
This was a week ago.
Got everything inventoried that night.
Apparently I started another primer war over on the VAF Facebook. Didn't know that was a thing.
I work in aerospace and have never been able to just put a part on an aircraft. It has to have some sort of protection on it.
I'm currently working on aircraft for my day job that have been sitting for 30 years in the arizona desert and it's awful. The system we use at work is like a 4 or 6 step process and was not something I was willing to do.
After researching I just ordered a batch of etch and prime from Stewart Systems. Sounds amazing... waterbased... roughly non toxic. I'll give it a try and go from there.
Old 04-29-2019, 10:09 PM
Kaffer62 Kaffer62 is offline
Congrats on taking the plunge... Glad to see another Phoenix area builder! Goodluck!
Frank Rivera
Peoria, Az
Rv-7 Tip Up/Tail dragger-Building
http://mykitlog.com/kaffer62
Old 04-29-2019, 10:25 PM
vernh59 vernh59 is offline
Welcome aboard! Im not too far down that road myself. Im really enjoying the journey so far.
Fly safe,
Vern
Ozark, Al
RV-7 Build No. 71139
Empennage Complete, Wings on hand
Starting Fuselage 11/15/19
https://eaabuilderslog.org?s=lhead
Exempt but gladly donating!
Old 04-30-2019, 04:11 AM
GeoffP's Avatar
GeoffP GeoffP is offline
There is something really cool about receiving boxes proudly stating "High Dollar Value Aircraft Parts - Handle with Care" in them!.
Good luck, have fun, and enjoy every second of building
RV-9, Empennage and Wings about done, Fuselage taking shape.
Old 05-07-2019, 03:21 AM
Roarks's Avatar
Sounded like they wanted it primer'ed
Tonights work:
Rear spar asm.
Maybe this weekend...
Got my care package from Stewart Systems in the mail today. Never used a paint gun so I might leave that to the weekend.
Old 05-08-2019, 03:52 PM
Roarks's Avatar
Well... this could be a little clearer.
So per the instructions it says to lay out a line of rivets...
Apparently the image for this is part of a SB 14-01-31?
See how this ends up.
Old 05-09-2019, 12:45 AM
Roarks's Avatar
Made my first mistake. HS Fwd spar. Match drilled through the HS-810-1 and got that on the other side
Emailed tech... not sure what I did wrong.
EDIT: Put them on opposite. New part ordered.
Old 05-09-2019, 07:38 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Don't let it bother you. I had to order replacement parts right off the bat too. Next time you screw something up, just have Vans throw in an extra trim tab skin too. You'll probably need it. I went through 3 of them I think
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
https://www.marksrv8.com
Old 05-09-2019, 08:50 PM
Girraf Girraf is offline
My plans showed the doublers very similar but have call outs indicating that the edges where they are connected are the bottoms and the outside edges are the tops which helps you get them oriented on the spar correctly. Looking again, your call outs basically say the same thing but not so clear as day. Just make a note for the future that when you have parts mirror image parts, they aren't always identical. Sometimes there is a left and a right version.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
