Old 04-15-2019, 05:15 PM
Mickrat Mickrat is offline
Default Leading Edge Check
Hello all,
This is my first post, been reading this site for months though.
I?ve recently started an RV-14A empennage kit. I wanted to check with you regarding the bend on my rudder leading edge.
Thanks.
Old 04-15-2019, 05:18 PM
Auburntsts's Avatar
It?s fine. You?ll never see it once it?s mounted to the VS.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-15-2019, 05:19 PM
bkervaski's Avatar
bkervaski bkervaski is offline
The goal here is to make sure the skin doesn't pull on the part underneath and develop a stress point. You want it to go out a bit and then start the curve. It took me more than a few attempts to get it just right.
What are you using to do the "roll"?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 04-15-2019, 05:22 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF, and Congratulations
Originally Posted by Mickrat View Post
Hello all,
Mick, welcome aboard the good ship VAF-----congrats on the build
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-15-2019, 05:54 PM
I used this 3/4” EMT. Drilled a 1/4” hole in the end for my screwdriver. It seems if I had a smaller radius I wouldn’t have enough material to reach the other edge.
Old 04-15-2019, 05:56 PM
unfluencer
Mick, mine didn't look that good.
Welcome aboard Sir.
v/r,dr
Doug Reeves (your host)
  • Part time: Contract Pilot (PIC type in Embraer Phenom 300). Flying resume.
  • Part time: Phenom 300 (currently) and Gulfstream 450/550 (soon) Seat Support at CAE (KDFW).
Old 04-15-2019, 06:14 PM
Mike S's Avatar
Senior Curmudgeon
May I suggest you get someone to look over your rivets before going too much farther.
Couple of these are not looking too good, not sure if this is a camera induce issue or not.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 04-15-2019, 06:37 PM
Girraf Girraf is offline
Agreed. Easier to fix them now.
Vintage Cherokee 160
RV-7:
Empennage complete
SB Wings to QB stage
Fuselage in progress
Finish kit/Engine/Prop Ordered
Old 04-15-2019, 06:43 PM
They don’t look great from that top view. Do they look better in the first picture?
Old 04-15-2019, 06:57 PM
Auburntsts's Avatar
Not really. The center vertical row of rivets that are in line with the hole all looked clinched, especially the top 2. That typically happens with a rivet that?s too long for the material thickness, but can happen for other reasons such as a misaligned bucking bar. A lot of the others look under-set but pics can be deceiving. Do you have a rivet gauge?
PP ASEL-IA
WAR EAGLE!
