Old 04-15-2019, 01:28 PM
dmat dmat is offline
Default Dimming a Rigid LED light?
I installed a set of Rigid lights to replace my old halogen lights. I tested them and they are super bright (which is a great thing!) but since I do care for all other pilots on the airport, I'm wondering if there is a way to dim them for taxi?
If not, I think I could use a 3 way switch to have one light on for taxi and both on for take-off & landing.
D
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 04-15-2019, 06:28 PM
fl-mike's Avatar
fl-mike fl-mike is offline
You could try wiring them in series for the taxi position. This will only work if they are using simple current limiting. If the circuit is ?smart?, they might not work at all, so bench trial first.
Mike W
Venice, FL
N164WM
Old 04-15-2019, 08:15 PM
rocketman1988 rocketman1988 is offline
Default or...
possibly a PWM controller...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 04-15-2019, 08:50 PM
Brantel's Avatar
Brantel Brantel is offline
Depends on what is inside the rigid light. If it has a built in constant current driver, it will likely not be dimmable.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-15-2019, 08:57 PM
lawnboy lawnboy is offline
They are not dimmable, they run on between I believe it's 9 and 36 volts give or take, but trying to run it below that will burn up the power supply circuit.
Old 04-16-2019, 05:40 AM
leok leok is offline
Default Possible solutions
Pretty much all flashlights have a PWM circuit to drive the LEDs and are not dimmable by variation of voltage. This is primarily to get long life out of the batteries.
You might be able to dim them by layering over a dimmable Buckpuck over the top, or a 555 timer chip set up in astabile mode driving a transistor power supply. It would take some tinkering to see if this would work. These parts are cheap and fun to play with.
You can Google the terms above for descriptions if you are not familiar with them.
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 04-16-2019, 06:03 AM
Default Maybe
https://www.amazon.com/Lighting-Cont...dimmer&sr=8-42
Bob
RV-10
297 HP Barrett Hung
Wiring...
Old 04-16-2019, 07:30 AM
fl-mike's Avatar
Sounds like a call to their technical support is in order.
"Are these lights dimmable?"
We look forward to hearing the "official" answer!
Mike W
Venice, FL
N164WM
Old 04-16-2019, 01:03 PM
Richard@Langair Richard@Langair is offline
Your best bet is to probably figure out a mechanical flapper of sorts to cover half the light when you want it dim.
I played with some HID headlights one time that used a system like that to provide high beams and low beams from the same projector style light. The light always stayed full brightness, but the flapper covered a portion of the light to provide the low beam.
I cant remember the light, otherwise I would show examples.
