Make a mount from hinge pins
I cut four rectangles of .063, 3/4" wide and a couple of inches long with a hole at each end. One end is attached using the bottom valve cover screw, under the existing adel clamp that holds the spark plug wires. Use the hole at the other end to attach a 1/8" adel clamp. Use that adel clamp to hold a piece of some of that discarded 1/8" soft hinge pin material that you removed from the cowl hinges.
When you're done, you'll have two long stiff wire mounts hanging below the spark plug wires on each side of the engine. You can use nylon spiral wrap to attach all your engine instrumentation wires to it. Be sure to use nylon spiral wrap, or it will melt. For added heat protection, automotive heater hose works great. Just split it down the middle and attach it with tie wraps.
Jon Baker
RV6A sold, RV4 in-progress
Houston
