Old 04-09-2019, 01:05 PM
rv7charlie rv7charlie is offline
Default Seat belt installation heads-up
I just purchased a set of used seat belts, and noticed that the way the belts were threaded through the double-slot adjusters wasn't consistent. I wondered which was the correct way to thread them through the adjuster (some had the free end of the belt going 'under'; some 'over'), so I looked it up.
http://www.crowenterprizes.com/Pages/Install.html
I then looked at the belts already in my -4, and they weren't consistent, either. I really don't know if it's a real safety issue, but I suspect that one way may not be as 'right' as the other. :-) Just thought I'd mention it as food for thought.
Charlie
Old 04-09-2019, 03:29 PM
Maxrate Maxrate is offline
Charlie, I checked mine and they were adjusted per the Crow instructions.
?LOCKING? the 3-bar Slide Adjuster shown in Steps 1-4 is VERY IMPORTANT. The 3-Bar Slide Adjuster must be located as close as possible to the Bolt-in bracket or Roll Bar (In Wrap Around design
Thanks for posting!
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
