04-09-2019, 09:24 AM
VS Lightening holes
I am starting an old kit R71139. I noticed my VS doubler did not come with the lightening holes like the newer kits. Is it worth cutting the holes? I"m planning on a tail dragging 7 slider.
Thanks in advance
Fly safe,
Vern
Ozark, Al
RV-7 Build No. 71139
Empennage Complete, Wings on hand
Starting Fuselage 11/15/19
https://eaabuilderslog.org?s=lhead
Exempt but gladly donating!
04-09-2019, 10:24 AM
Holes
Any weight savjngs that far back is worth doing. Grams add up. Holes are not difficult to cut but you could always buy a newer one with holes.
If you choose to cut them I would use hole saws. Drill the pilot hole smaller than final and use a 1/4" reamer to get final dimension. Replace the pilot drill with a 1/4" polished steel rod so it can't enlarge the hole while it turns. Clamp everything down and cut away. No problem.
Here's a link.
https://drive.google.com/open?id=0B7...U9zVXBLeHFuaEk
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
04-09-2019, 02:40 PM
Add Lightness
What Larry said. Lose weight wherever possible, as long as you don't compromise strength.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
04-09-2019, 07:38 PM
[/url]
I'm in the same situation and looking at the cost/time/effort to tool up to cut the holes myself vs. buying a pre-cut part, the new part wins and the old will undoubtedly be recycled into something else.
Not to drift the thread.....
But, does anyone know if the older HS-601PP elevator skin is compatable with the newer PP parts?
The HS-601PP is called out in both my build binder and the newer preview plans I have.
Practice Kit completed 2/19/2017
Tooling up for -7 empennage build.(100% tooled 1/31/2018)!
Orphaned -7 empennage kit purchased! 9/15/2017
-7/8 Rudder 25% complete.
2019 Donation paid...
04-10-2019, 08:03 AM
Did it
I went ahead and cut the holes using a 2" and 1.5" hole saw. Take your time and they cut right through it. I smoother the cuts with a small flap wheel and some Emory paper. On to the next thing
Fly safe,
Vern
Ozark, Al
04-10-2019, 09:30 PM
VS holes
I have an older -8 kit, do you have a picture of the newer plans showing the lightening holes?
Tom
Las Vegas
RV-8 empenage almost finished
Horizontal Stab done! 2-15-2020
Vertical Stab Done! 5-27-2020
Rudder Done! 5-31-2020
Wings ordered!...
04-10-2019, 11:58 PM
Yes!
Yes! Awesome, thanks!
Tom
Las Vegas
Wings ordered!...
