Old 04-05-2019, 11:54 AM
CaptainQwyx's Avatar
CaptainQwyx CaptainQwyx is offline
Default RV-10 HS-1016 Dinged
So since Van's Support staff is away at Sun-n-Fun, I turn to y'all.
RV-10, page 8-10, Step 2. The rivet gun jumped a bit while riveting one of the corner rivets attaching the HS-1016 Stringer Web to the HS-1014 and -1015 Stringers. Some slight deformation, no actual cracks or creases. Pictures below...
I need to know if this is a critical component or is this superficial, cosmetic damage and can build on?
Jeff Anderson
Midlothian, TX
VAF dues paid 08/2018
Old 04-05-2019, 04:01 PM
-goose -goose is offline
Inspect the dents carefully for cracks, if none then give it a quick whizz over with a scotchbrite wheel in your die grinder to soften any hard edges only, prime and carry on. Have a good look at what that dark line is just at the top edge of the rivet head - a paint chip or something more serious? Don't replace the rivet it is serviceable and trying to change it out may give a worse result.
John Keen
RV-7 flying
Gold Coast, Australia
Old 04-05-2019, 04:30 PM
cderk's Avatar
cderk cderk is online now
Looks like it?s probably fine, but definitely check for cracks like stated above. You may also want to check to make sure those rivets are set properly. Pictures may be at strange angles but the ?shop? head on that rivet doesn?t look right.
Old 04-06-2019, 01:10 PM
jacoby jacoby is offline
Are you using the correct size set in your rivet gun? Looking at that mark on the factory head to the left it almost looks like you are using a -3 set instead of a -4. That would explain it wanting to jump off the head as well.
It may be camera trickery but the dinged rivet shop head looks crooked along with the topmost rivet on the right side of your first pic.
Old 04-06-2019, 06:25 PM
Thanks for the replies everyone. The dark spot is just where some of the primer rubbed off as I was trying to smooth things out. There's definitely no cracks so I'm just going to build on.
Jeff Anderson
Midlothian, TX
Old 04-07-2019, 09:09 PM
PilotjohnS PilotjohnS is offline
Default Rule of thumb
When looking at pictures, it is hard to tell if the shop head is proper since it is difficult to accurately measure. However, with a rule of thumb of .5 dia high and 1.5dia wide, the rivets should have a 3:1 aspect ratio. I think this is why someone above implied to check the rivet with a gauge. YMMV
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2021, worth every penny
RV9A- Status:
95% done, 5% left to go
Electrical/Panel done
Firewall Forward 95% done (waiting on fiberglass to be done)
Fiberglass 5%
www.pilotjohnsrv9.blogspot.com
Old 04-08-2019, 12:30 PM
dwrichey's Avatar
dwrichey dwrichey is offline
You may be able to mitigate some of the aesthetic with judicious hammering with two bucking bars and a hammer. Hold the bucking bars flat!
