Bearing bolt
Sean
My bearings were adjusted when the tail feathers were mounted and drilled. I used a long section of polished steel rod inserted through the bearings then measured using a caliper. All were set to 7/8". If they are not equal, it's quite possible the horns could be out of position enough for the hole to fall close to the horn shaft. Clamp the elevators in trail then drill. My holes are clear enough for hardware. About 3/8" from the shaft.
By the way, I manage a Google Group of builders in Colorado.
If you would like to join, shoot me an e-mail from a Google account.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
