Old 04-02-2019, 10:48 AM
pilot28906 pilot28906 is offline
Default Cleaning Inside of Cowling
I have some drips of a red (preservation?) fluid that has dripped out of the fuel injection servo and got onto the bottom cowling. This happened while I was fitting the cowling. How is the best way to remove this before sealing the inside of the cowling?
On sealing the cowling. Can I do this using the West system applying a thin coat then apply the foil?
John
John Johnson
Murphy, NC
RV7
Old 04-02-2019, 11:45 AM
DanH's Avatar
DanH DanH is offline
John
MEK.
Seal and finish two-part paint the inside just like the outside. The foil will stick forever.
Dan Horton
RV-8 SS
Barrett IO-390
Old 04-02-2019, 02:59 PM
Stoo Stoo is offline
Use K2r spot lifter. This will suck the oil out of the fiberglass so you don't run into any adhesion problems with the epoxy. I gave the inside of my cowl a coat of West Systems epoxy tinted white with pigment from Aircraft Spruce. The aluminum foil sticks well to this.
Stewart Willoughby, 6 paint is next.
Old 04-02-2019, 06:22 PM
Thanks for the info.
Is K2r the clothes spot remover?
MEK is OK for the inside of the cowl? If so, I have some.
John Johnson
Murphy, NC
RV7
