  #21
Old 04-02-2019, 08:06 PM
PhatRV PhatRV is online now
I tested my tanks with water before closing the baffle. I was glad I did that because I discovered a couple of leaks and it was easy to fix them with the tanks still opened.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
Old 04-03-2019, 12:12 PM
BrianDC's Avatar
BrianDC BrianDC is offline
Guess I'm planning on bucking some of the advice given in this thread.
Currently I think I'm in about the same place as Roman. Tanks are built but have not installed the back baffle. I have been waiting for weather to warm up (no freezing overnight) before I fill my tanks with water and leak test them.
Cap off all fuel and vent ports, install fuel cap, and fill with as much water as possible. (maybe add food coloring). Put tissue paper on outside of tank rivet lines to "detect" any possible water leaks. Let sit 24 hours max?
Once successful I can drain, clean and dry tank before installing baffle. At this point I can do an air pressure test as recommended by vans (Balloon test?)
If that is successful, I will declare success until just before first flight when I will hopefully be able to test with 100LL (or whatever replacement comes out. HA!).
Don't have any way to store 100LL in my garage and don't want to put a large quantity of fuel in an open container (unfinished tank) for any length of time. Don't want all those gas fumes. Totally see the points others have made, but not sure it's practical (at least for my situation).
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - Done (for now)
Fuselage - Done (for now)
Finish Kit - in progress
RV10builder.com
KVKX / KHEF
Old 04-03-2019, 01:41 PM
BillL BillL is offline
Brian, at least go to the grocery store and buy bulk RO water with less than 10 PPM TDS water, it will be the safest. Some ground water is so bad that entire communities use RO treatment. You can buy a TDS meter from freshwatersystems.com. Dasani bottled water is 125 PPM --to much. My local Kroger store has bulk-by-the-gallon water and it is 5 ppm.
Bill
RV-7
Lord Kelvin:
Old 04-03-2019, 07:35 PM
majuro15's Avatar
majuro15 majuro15 is offline
No need for coloring or tissue paper. Trust me a drop is visible.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
