Old 04-01-2019, 07:20 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Cowl clearance for engine ?
I must modify my SJ cowl to fit a 360 w/dynafocal / AFP 150 updraft and custom FAB. I have read numerous opinions that the baffle/plenum should clear the top anywhere from 1/2" to 3/4".Same for FAB to cowl ( horizontal ) clearance 3/4" to 1".
Can anyone confirm how much clearance is 'required' ? I know a "bunch" would do the job but I am constrained for space and need to sharpen my pencil as much as possible. Thanks
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 04-01-2019, 01:12 PM
Raymo's Avatar
Raymo Raymo is offline
I had the same issue on my -7A, Larry, but managed to get about 1/8-1/4" clearance. This was only a problem toward the aft, left middle section. No rubbing has occurred.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 04-01-2019, 06:10 PM
BillL BillL is offline
RV7 - the outboard edges of the plenum/baffles (to cowl) 1/2" but 5/16" is good. The front corners are likely the tightest to the cowl due to engine rocking.
Just keep in mind what is happening - landing, aerobatics, and engine rocking due to starts or shutdowns.
Vertical clearance over the top center of my plenum is 5/16"
Longitudinal clearance between the cooling rings to the plenum - mine are 1/4" and work fine, no touching, the same for the engine air inlet ring to FAB.
The base of my conical (SJ) FAB is 1/4" or less and is rubbing a hole in the cowl. It touches at 3 G's.Recommend at least 1/2" due to G loading and deflection. Maybe when bouncing on landing -
Hope this helps.
Bill
RV-7
Lord Kelvin:
Old 04-02-2019, 10:06 AM
Raymo's Avatar
Another point to make (at least with mine) is that the engine will rise about a 1/4" in flight vs sitting on the ground, which means you can raise the upper cowl that much such that it will be even with the spinner in flight. YMMV
Ray
