  #21
Old 04-12-2019, 06:40 PM
N941WR's Avatar
N941WR N941WR is offline
Default Fuel Pressure?
Last night, I ran the plane as part of the final Condition Inspection Opps check.
The fuel pressure was spot on, it functioned as expected, with the electric pump on and off.
This evening I had a chance to fly the plane and for the first three quarters of the flight the fuel pressure was exactly what I would expect.
Then it started climing and triggered the high fuel pressure alarm.
I'm carburated and the SkyView went crazy with 27 PSI of fuel pressure. Turning on or off the electric pump didn't seem to make much difference.
I landed, shut the engine down and noticed the fuel pressure was reading 17 PSI with everything turned off.
Hummmm?
Tomorrow I'm going to replace the ground wire for the sensor. I have an older sensor that I can put back on, if a new ground lug doesn't fix the problem.
So, I sent from low fuel pressure to high fuel pressure. Go figure!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-12-2019, 07:34 PM
grubbat's Avatar
grubbat grubbat is offline
Default 320 is the one
Bill is a maverick. Don?t put a 360 on the -9. The 320 does just fine and with a constant speed prop, it?s a sweet combination. Besides the -360 is too much power for that airframe. Also, If you do decide to forge ahead with a 360, then it could cause blindness. Just fair warning.
I guess I would be remis if I didn?t share that my 180+hp with CS prop -9 is a takeoff thrill similar to my old RV-3. Off the ground in several seconds, Pattern altitude halfway down the runway, it?s a rush every time. As far as cruise speed, im a 180mph TAS everywhere kind of guy.
Good luck on your build. It?s the best kept secret of all the Vans designs.
Ok Bill, back to your condition inspection......
Originally Posted by flyabq View Post
I love the engine. I just know Van's position on the 360 on the 9, and I am wanting to put one on when I finally get the Fuselage done. I am trying to decide on that and the 320.
Craig
RV-3 Sold
RV-4 Sold
RV-6a Sold
RV-9 IO-360 CS, Built and Flying
Aerostar 600A, Family Hotrod
Old 04-12-2019, 08:48 PM
N941WR's Avatar
Originally Posted by grubbat View Post
Bill is a maverick.
I thought it was something I did during puberty that caused the blindness Craig!
I just had a conversation with someone else on this board about starting to collect parts for a CS prop for the HurlMaker II.
Bill R.
SC86 - Easley, SC
Old 04-13-2019, 08:19 AM
Greg Arehart's Avatar
Bill,
Are you using the standard Vans fuel pressure transducer? Just wondering as I recall that a number of folks (myself included) have had these go to high P, presumably because of a ground issue. I'm now seeing this (high P) very intermittently on my second sender and thinking about replacement options.
Maybe something about the o360 in a 9? ;>)
Greg
Greg Arehart
N 7965A
Old 04-13-2019, 08:23 AM
N941WR's Avatar
Originally Posted by Greg Arehart View Post
Bill,
Greg
Greg,
Yes, I have the Van's sensor. I'll play with the ground wire and see if that fixes it.
But, you are correct, it could be the course of the big engine in a -9!
Bill R.
SC86 - Easley, SC
Old 04-13-2019, 02:02 PM
molson309 molson309 is offline
Bill,
Greg
If you are using the VDO sender they fail by the resistance wire wearing out at the usual place the wiper (run by pressure) sits when the engine is running. So your fuel pressure may read normally when the wiper bridges the spot on the wire, and suddenly peg high - or to zero - when the pressure changes a bit.
Mark Olson
RV-7A First flight 2005 Sold 2019
F1-EVO Rocket First flight 2010
Old 04-15-2019, 06:09 PM
N941WR's Avatar
Just landed after an hour's test flight, fuel pressure issue seems to be resolved.
I ohm'ed out the ground wire and it was faulty. I replaced the connectors on both ends and all is good.
Sometimes it is the simple things!
Bill R.
SC86 - Easley, SC
Old 04-16-2019, 09:24 AM
airguy's Avatar
airguy airguy is offline
Like he said, put the IO360 and CS prop on the plane, and you'll never question it. There's nothing like passing the Bonanza that took off in front of you during the climbout.
Old 03-09-2020, 06:41 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Originally Posted by N941WR View Post
Condition inspection completed and logbooks signed.
The only thing that needed to be replaced was the right side neoprene tube that goes from the aluminum inlet to the cooling plenum on my Sam James cowl.
With the two engine runs I performed, the fuel pressure was perfect. So, bleeding the fuel pressure line may have solved that annoying issue. I won't know until I fly it. That may have to wait until next weekend as we are supposed to get three days of rain here in the upstate of South Carolina.
So almost a year later, did bleeding the fuel line definitely eliminate your low pressure readings or did the problem return at any time?
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
