Old 03-30-2019, 12:05 AM
charosenz's Avatar
charosenz charosenz is offline
Default What is the proper edicate for dual postings?
I have a post that seems to fit in two threads. I have heard it is not proper to post it in two different threads. Is that right?
If so, then I just need to pick one thread and then may be post a link to it in the other thread?
Not that it matters but it is about my personal test comparison on pulled rivets.
Charlie
Old 03-30-2019, 01:47 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default one place
You should just pick a place and put it there. Sometimes if it's really in the wrong place, a kind moderator will move it to what they believe is a better place. Moderators usually remove duplicate posts.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-30-2019, 07:55 AM
Snowflake's Avatar
The etiquette is: don't dual post.
Most of us read the forum by hitting the "New Posts" button anyway, so we'll just see it twice. Which subforum the post is in is largely irrelevant.
Rob Prior
Old 03-30-2019, 08:02 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Yep, agreed.
While the above is pretty much correct when the posting is current, it is a different animal altogether when someone goes searching for a specific post/thread a year or two later.
The main reason I move things to the forum that (IMHO) fits best is for later simplicity in finding it.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-30-2019, 09:26 AM
charosenz's Avatar
I thought the dual post was unwelcome, I just could not find it in the instructions or "read tis" section so thank you.
Just to clarify....Is providing a link to it in a different thread also a problem?
Thanks.
Charlie
Old 03-30-2019, 09:38 AM
Mike S's Avatar
Senior Curmudgeon
Thanks.
Charlie
Not as far as I am concerned------I do it now and then.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 03-30-2019, 09:44 AM
Mike S's Avatar
Senior Curmudgeon
http://www.vansairforce.net/rules.htm
Scroll down to the taco truck, list is to the right. Item 5.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 03-30-2019, 07:49 PM
Sam Buchanan's Avatar
been here awhile
Thanks.
Charlie
If the sole purpose of the second thread is to provide a link to the other thread......that is double posting, and will most likely be deleted by a moderator.
Just pick an appropriate sub-forum, post once and there is no problem.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 03-31-2019, 09:49 AM
Snowflake's Avatar
As someone who used to religiously sort my emails into folders for "easier finding later", I can say with certainty that this is a wasted effort. The Search function will find the posting faster than scrolling through individual forums.
A much more valuable feature would be the ability to tag posts with categories, and allow multiple categories per post. Then one could select posts by category if they felt they needed to see just posts related to that category.
Rob Prior
Old 03-31-2019, 10:24 AM
Mike S's Avatar
Senior Curmudgeon
Aha, but I see no reason to scroll through each forum, you can direct the search to look in a specific forum.
Saves lots of false hits from the various forums that are not the correct subject.
Mike Starkey
VAF 909
Rv-10, N210LM.
