Sorry for appearing dramatic, but I find this thread to be truly SCARY!
I too am in league with earlier posters who advise to "DON'T DO IT." But I will go a bit further to suggest what you should do.
You should contact the fuel injector manufacturer technical support and describe what you are experiencing (or trying to prevent experiencing), describe your non-standard fuel plumbing set-up, and follow their suggestions. Also talk through what is, and how to prevent 'vapor lock' with them.
I did a quick web search and found that at least one manufacturer offers a purge valve set-up that mounts on top of the engine to clear vapor lock from the fuel spyder, you might institute this type of solution for hot starts.
In the mean time, if you go flying CLOSE THAT VALVE!
As Scott said:
"Be very careful when designing / modifying the fuel system for an aircraft.
Fuel system issues is one of the highest causes of engine stoppage in experimental aircraft.
Ralph
built a few RVs, rebuilt a few more, hot rodded some, & maintained/updated a bunch more
