Old 04-16-2007, 07:48 AM
pierre smith's Avatar
Default D180 magnetometer tilt?
Mornin' guys,
I was helping a buddy install his magnetometer in his -4 yesterday and the instructions said to tilt it the same amount as the D180. It worked out to 10 degrees but is it really necessary? If so, why? The other axes also are required to be aligned with the D180 as well, and this make sense.
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-16-2007, 11:32 AM
Kevin Horton's Avatar
The lines of force in the earth's magnetic field are sloped. The magnetometer measures the 3 components of those lines of force, and the calculations need to know the pitch angle of the magnetometer. The calculations assume that the pitch angle of the magnetometer is the same as the EFIS. If you don't put them at the same angle, expect errors in the heading.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 04-16-2007, 05:14 PM
az_gila's Avatar
az_gila az_gila is offline
Question 8 degrees???
Aren't the RV-6 panels at an 8 degree tilt (not 10 degrees) to the longeron reference line?
UPDATE
Oops... I see you have the -6 not the one you measured - a -4 .....
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-17-2007, 07:28 AM
Default Yes but
Yes Gil,
The panel tilt is 8 deg to the longerons. However, the longerons take a downward bend forward of where the airplane's level point is by about 2 degrees. The math is....well, y' know. Our 6 does this too.
You're observant, eh??
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
