Old 03-26-2019, 08:08 PM
Lynnb's Avatar
Lynnb Lynnb is offline
Default Throttle and Mixture Cable Routing
So I'm using Van's Throttle Quad and Standard cables, I went to route them tonight to check the lengths were good, which they are, but the clearance around the engine for the Throttle cable is really tight. I ran the mixture cable under the engine mount and I think it will work, just wondering how others have routed theirs and am I missing anything. (see pics.)
Thanks for any input,
Lynn
RV-10
First Flight 12-17-2020
Old 03-26-2019, 08:21 PM
I ran mine the other night. Different induction setup though. What you have doesn't bother me. What I will say is that (depending on how the cable end geometry works out) you have what looks like an inch to play with by adjusting the nuts clamping the cable into place. That would give you a little more slack.
Also, I'd try to use a pair of adel clamps to keep that cable off of the engine mount tube.
Alternately, I have a spare 52.5" cable if you're interested. I have the vertical induction FM-200 and needed shorter throttle and mixture cables. I was able to repurpose the 49.5" cable to the mixture and substitute it for the 52.5" cable, but I had to order an even shorter cable for the throttle.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-26-2019, 09:06 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Consider exchanging the recommended 47.5? RV-10 throttle cable with the 50.5? RV-7 throttle cable. Bend the mounting bracket down a touch as well. I did this and it worked out well.
Stock Van?s IO-540 engine.
Carl
Old 03-26-2019, 11:06 PM
lr172 lr172 is offline
Kyle,
I am interested in that throttle cable if the OP doesn't take you up on it. Is it a std knob or a quadrant cable? I fear my stock cable may be to short. Engine should go on in mid-April.
Larry
Old 03-26-2019, 11:13 PM
Originally Posted by lr172 View Post
Kyle,
Larry
Quadrant cable. Haven't heard from the OP. Let me know.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-27-2019, 06:59 PM
Lynnb's Avatar
Thanks for all the feedback and the offer Kyle, my cable lengths are good, just mostly wanting to make sure I wasn't missing some trick.
Lynn
RV-10
Old 03-27-2019, 10:45 PM
Disregard. I am not using a quadrant. Thanks any ways.
Larry
