Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
Old 03-26-2019, 12:29 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Default G3X Touch Software V8.20 now available 3/26/19
While the G3X was being certified, Team X continued to move forward with software features for the E-AB and LSA markets. G3X Touch software 8.20 is now available for non-certified aircraft and can be downloaded from the Garmin website:
https://www8.garmin.com/support/coll...t=010-00G3X-00
Rev L of the G3X Touch Pilot’s guide is now available for download for more information on these new features.
https://support.garmin.com/support/m...o=010-00G3X-00
New Features
• FIS-B weather products weather products have been expanded to display the following new products:
o Lightning
o Cloud Tops Forecast
o Turbulence Forecast
o Icing Forecast
Here are the currently available FIS-B weather products available when connected to a GDL 39/39R/39 3D, GDL 50/50R/52/52R, GNX 375, GTX 345/345R/45R:
Note: In current software, these 4 new FIS-B weather products are only available over a Bluetooth connection. If you only have an RS-232 connection to your ADS-B receiver, it is recommended to add a Bluetooth connection to receive the new weather products.
• Added support for the new GPS 175 and GNX 375 IFR navigators. The GAD 29 is required when interfacing the G3X to the GPS 175 or GNX 375.
You can check out these great new products on our website:
GPS 175: https://buy.garmin.com/en-US/US/p/577202
GNX 375: https://buy.garmin.com/en-US/US/p/577174
Or check out the VAF announcement for the new navigators:
http://www.vansairforce.com/communit...d.php?t=169969
• Added support for GAD 29B and analog autopilot interface with GPS Steering (GPSS)
• Added Percent Power on EIS strip for the Rotax 915 iS FADEC engine.
• Improved audio to play “Engaging Autopilot” aural message on top of AOA tones
• Includes G5 software version 6.10 which adds the following:
o Display of True Airspeed (TAS) and Outside Air Temp (OAT) on the PFD page.
o Display of wind velocity and direction on top left of HSI page and Course (CRS) digital readout on bottom left side of HSI Page
• General System Improvements
See the Garmin website for a full list of software versions and changes associated with Software Version 8.20.
Levi Self
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
Old 03-26-2019, 01:22 PM
gfb gfb is offline
Been looking forward to the new adsb data!
Thanks!
RV-9A - started 01/2015, completed 07/19/2018, 500hrs 03/14/2020
RV-10 - started 04/2020
Old 03-26-2019, 01:33 PM
bsvantho bsvantho is offline
Looks great.
The download link for the software is working, but the link to the new manual appears to be broken. Please check.
How can I confirm I have a Bluetooth connection established between the G3X and ADS-B receiver to receive the new weather products? In my case I have the GTX 45R.
-Brendon
RV-10
Old 03-26-2019, 01:44 PM
Originally Posted by g3xpert View Post
Note: In current software, these features are only available over a Bluetooth connection. If you only have an RS-232 connection to your ADS-B receiver, it is recommended to add a Bluetooth connection to receive the new weather products.
My original GDL-39 is connected via serial data.
I don't recall ow many concurrent Bluetooth connections the original GDL-39 supports ans I assume making this change will reduce that by one? How many are left for portable devices?
Old 03-26-2019, 01:50 PM
Brantel's Avatar
Brantel Brantel is offline
The GDL-39 can have one hardwired and 2 BT at the same time.
I have one screen hardwired and one BT and the 2nd BT connection available for the Tablet. Works great.
I don't plan to switch anything up, I will just look at the second screen or the tablet for these new products. Hopefully future software will fix the RS232 link to support them. I imagine the protocol will need to change since it was developed long before these new products were announced.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 03-26-2019, 01:55 PM
Thanks. I am not planning to add the BT connection.
TBH, what I need are bigger winds aloft flags
Old 03-26-2019, 04:03 PM
Paddy's Avatar
Paddy Paddy is offline
Default G3X Non-Touch
Any news on a software update to the legacy G3X (non-touch) to enable the use of the GTN vertical nav feature specifically?
RV-10 N415JS
Slow build kit #40874
Homebuilt Kit Champion Oshkosh 2019
Atlantic crossings: 2
Old 03-26-2019, 07:35 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Just flew 1.5 hours on 8.20 checking out the poppy/wildflower bloom in Antelope Valley and everything behaved itself as far as I could tell.
I see the Flight Logger is back to recording each flight as a discrete flight rather than lumping all legs of a round trip together as 7.00 did.
Old 03-30-2019, 06:38 PM
Bavafa Bavafa is offline
I updated mine and see the new features but for both "cloud tops" and "lighting" I only see "Waiting for data"
Is a user issue, equipment/SW issue or ADSB system broadcast issue?
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - SOLD
N258SM RV14A - IO390EXP119 - in progress
Dues paid
Old 03-30-2019, 08:41 PM
Greenley's Avatar
Greenley Greenley is offline
Link for pilot guide still not working.
Bill Greenley
My RV-10 is now traveling, watch out world!!!!!!
