Old 03-25-2019, 11:23 AM
pilot28906 pilot28906 is offline
Default Heater Fresh Air Supply
I need to cut the hole in the baffles for the fresh air supply for the heat muff. I think the heat muff will go on the #1 cylinder exhaust pipe. Does the 2" fresh air hole go in the right side cowling inlet baffle ramp? Does it matter where on this ramp? I have the 180 HP horizontal induction IO-360 Lycoming.
John Johnson
Murphy, NC
RV7
Old 03-25-2019, 12:14 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Which exhaust are you installing? For the crossover with heat muff on cyl. #1 it will be located in the front right inlet ramp per drawing OP-33.
If you are using the 4-pipe with 2 pipe heat muff then it will come off the rear baffle behind cyl. #3 per instructions that come with the baffle kit. I don't have that readily available. I'll scan and post pic tomorrow unless someone beats me to it.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-25-2019, 12:18 PM
John Tierney John Tierney is offline
I have a similar engine with a cross-over exhaust and that is where I put my air intake hole and heat muff. I got a 90-degree duct adapter from Van's to make the intake hose connection work from the intake ramp to the muff, then ran my scat tube beneath the cylinders but above the intake and exhaust tubes on the right side.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 03-25-2019, 02:06 PM
Capt Capt is offline
As a side note the warm air source for my RV8 comes from the exhausted air that passes thru the firewall mounted oil cooler. I have a cockpit controllable flap to either direct the spent warm air into the cockpit or overboard, works well with not threat of exhaust fumes. Just another option is all
Old 03-25-2019, 05:49 PM
Yes, I have the Vetterman crossover. Thanks for the info, I found the drawing.
John Johnson
Murphy, NC
RV7
Old 04-20-2019, 12:40 PM
RV74ME RV74ME is offline
So I'm trying to install my heat muff now (Rv-7, IO-360, vetterman exhaust)....
Just trial fitting the scat tube under the 1&3 cylinders, inside the intake/exhaust tubes per the plans. Needless to say, it's going to be a real challenge to keep it from touching anything! And it looks like it will be really close to the #3 exhaust.
Anyone have pics on how they did this?
Steve T.
CFII/MEI/ATP 737,DC-10
RV-7 slow build
AUO
