Old 04-15-2007, 07:56 PM
Default Cable Tie Tool
Once upon a time, a buddy loaned me a tool that automatically tensioned and cut cable ties (also known as tie wraps, zip ties, and probably several other names). The big advantage of this tool is that it properly tensions the ties and cuts 'em off very close to being flush. That way, your risk of being sliced open by a protruding cut-off end goes down a bit.
Anyway, I'm in the market to buy one, and I can't get in touch with the guy who loaned me his in the first place. I've found several possibilities on-line, Google being my friend and all, but the descriptions are lacking on most of 'em. The one I'm looking for is a hand tool - no power and doesn't need to be twisted to cut the cable ties. In addition, it has the ability to tension and cut the three common sizes of zip ties you'd find in the bulk section at Home Depot.
Can someone point me in the right direction? Maybe post a link?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-15-2007, 08:27 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Check with Stein?? Or B & C?
Mike
Old 04-15-2007, 08:32 PM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Default panduit gun
What you're looking for is a Panduit gun. I have two of them, one is for large ties, the other is for small to medium ones. I bought mine off of EBay and paid about 25 or 35 dollars for each of them. They sell for over $300.00 new. These are used in production line work at Boeing, both of mine had Boeing serial numbers engraved on them. I use the smaller one much more commonly than the larger one, it's a Panduit GS2B. Once you get one of these babies, you'll wonder how you ever lived without it!
RV7A-QB, RV-10
Old 04-15-2007, 09:05 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Greenlee...
Mine is out at the hangar, but I believe I remember that it was made by Greenlee, the same folks that make sheet metal hole punches. I found it at an electronic specialty parts store for (if I remember correctly) about $40. I'm too cheap to have paid more...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-15-2007, 09:31 PM
scard's Avatar
scard scard is offline
Yep, I have one of the Panduit tools. Paid the full new price from either Mouser or Digikey. Well worth it if you have the money to spend on nice tools. For the right (metal) model, I don't see any reason that the well used model off of ebay wouldn't work as well as new.
Scott Card
CMW E-Lift
Old 04-16-2007, 02:38 AM
AlexPeterson's Avatar
I bought a nice one at a local hardware store, it is metal and plastic, and made in Germany. I don't have access to it right now, but it is nice and cost around $20. The main body is blue.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
