Originally Posted by rvbuilder2002
Since it is my post you are referencing, I thought I should clarify.....
When I wrote "That is why the one with sharp corners will be stronger", it was in the context of comparing the two examples in the the diagram that was attached to that post.
That should not be taken to mean that sharp corners on fastener holes are good (they aren't), just that the sharp hole shown in the diagram would be stronger than the one with excessively deburred holes. Particularly with bolt fasteners because of the improved baring area of the hole interior on the bolt shank.
Holes should always be deburred... just not excessively so.
Thanks for the clarification. I was hoping you'd chime in. I didn't really mean for this thread to drift into technique, but here we are. I just wanted to show the difference between the two discs since I know some are using them in their builds.
