Old 03-21-2019, 05:08 PM
unfluencer
Default RV Law of ?
A stab at comedy. I’ll get the ball rolling with:
"RV Law of Clean Leading Edges / Dirty Belly"
If you just clean the leading edge of your wings after a flight, the longer a visitor stares at them the probability of them believing the belly is also clean approaches one.
Doug Reeves (your host)
  • Typed in the EMB-505 (Phenom 300). Available for contract work. (flying resume).
  • Part time: Supporting Crew Member CAE EMB-505 Level D Sim @ KDFW.
Old 03-21-2019, 06:06 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
Default Law Two
RV LAW OF STATED PERFORMANCE NUMBERS
If you state any performance number on your craft someone in the audience will have always have a better one for theirs.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 03-21-2019, 06:47 PM
wirejock's Avatar
wirejock wirejock is offline
Default RV Law of Tailwheel Superiority
If you even think A model, be prepared for the fuel and flames.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 03-21-2019, 07:56 PM
plehrke's Avatar
plehrke plehrke is offline
Default The law of
The RV humility law
The more someone compliments you on your workmanship on your RV, the more mistakes and dings you will point out.
Philip
RV-6A - flying 970+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 03-21-2019, 09:03 PM
mturnerb mturnerb is offline
RV humility law corollary: As soon as you start to think you are a competent builder, you bungle a part and humbly call the mothership for a replacement.
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 03-21-2019, 09:22 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default ... Vectors.
The RV Law of Vectors.
No matter how many times you checked...
? and rechecked...
...no matter what precautions you took...
? the drill bit is ALWAYS perfectly aligned dead center with your thumbnail.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2021 -=VAF=- Contributor
PS: I am not an influencer. I have no influence. Just ask my kids.
Old 03-21-2019, 10:11 PM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
The RV Laws of Opinions
1st Law: "The first law states that for every opinion about building/flying/maintaining an RV, there is an equal and opposite opinion."
2nd Law: "The second law states that the entropy of any discussion about an opinion will always increase."
3rd Law: "The third law states that the entropy of any discussion around an opinion approaches a constant value just prior to being locked by a moderator."
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 03-22-2019, 06:18 AM
PCHunt PCHunt is offline
Originally Posted by DeltaRomeo View Post
A stab at comedy. I?ll get the ball rolling with:
But if you just walk away without ANY cleaning, the visitor with think the plane is already clean. And if the visitor was a passenger, they will be so thrilled with the flight that no amount of dirt/grease/oil will be even slightly noticeable, because they are not nearly as anal as we are!
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2021 Donation+, Gladly Sent
Old 03-22-2019, 07:55 AM
BigD BigD is offline
Default The Law of Auto-Resolving Problems
If the aircraft starts to make a strange sound and subsequently the sound goes away, the problem has not resolved itself; there's at least a 50% chance it's gotten worse.
==dave==
Old 03-22-2019, 08:36 AM
XOverZero's Avatar
XOverZero XOverZero is offline
Default The Law of Perversity Tending to the Maximum
  • Everything affects everything else. There?s no such thing as one domino.
  • Any small item dropped while working in the engine compartment will never come out the bottom.
  • Any small dropped item that hits the floor will not be in the direction you saw it bounce.
  • The ?most likely? explanation/cause/solution is only applicable to other airplanes ? not yours.
  • There are only three places in RVs that fuel leaks will occur:
    • bad places;
    • really bad places;
    • and much worse places.
  • There?s always something.
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"Keep flying. Malcolm Reynolds
Paid up until Aug 2022
