Old 03-17-2019, 08:33 PM
Default Wing intersection fairing assistance
This is for an RV-6A, but RV7-A info may help as well.
For those that have already completed the wing intersrction fairing, I would appriciate a picture of how you finished the aft edge on the top and bottom.
For the top, where is the farthest aft screw, is it still in the rib, or did you try to squeeze one in just forward of the flap?
On the bottom, did you interface with the bottom fuselage skin? Tuck it under or share a screw?
The RV-6A plans leave a lot to the imagination in this area. I'd like to see what has worked for others. Thanks!
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 03-18-2019, 07:42 AM
FinnFlyer FinnFlyer is offline
On my RV-4 I put a nutplate as far back as I could without the nutplate (with screw) touching the flap.
I had a spare 0.025 sheet of 2024-T3, so fabricated one continuous strip from bottom center fuselage skins over wing tip and back to rear of top skin. I guess the same could be done on RV-6/7.
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 03-18-2019, 08:57 AM
Raymo's Avatar
Raymo Raymo is offline
The -7 plans have nutplate locations specified. PM me your email and I'll get you a copy of that drawing.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
Old 03-18-2019, 01:03 PM
Finn
Finn,
Thanks for the info. I have a continuous strip as well, it is really that aft screw I was worried about. Sounds like I can cram one in.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Ray,
Sent you a PM, thank you
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 03-18-2019, 01:15 PM
219PB 219PB is offline
Colin,
My website has a couple of pictures of my wing intersection fairings. Look at them and see if you can get the info that you need. If you do not, let me know and I will go out to the airport and take some close up pictures for you. I installed the wing fairings a couple of years ago and they fit perfectly.
Paul Bonorden
RV-6A Flying
My Builders Website
Victoria, TX
Old 03-18-2019, 02:31 PM
Originally Posted by 219PB View Post
Colin,
Paul,
I looked through your log (project looks great), the one thing I dont see is how you terminated the aft end of the fairing on the bottom. Did you put it on top of under the fuslage skin, or just trim it to butt up?
Colin
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
