Old 03-17-2019, 03:45 PM
ATango ATango is offline
Default Carbon Fiber Rudder
I've been working on making a carbon fiber rudder (RV-8 drop-in replacement) for a little while now and finally have a little bit of progress to share. I just fabricated the skins this past week while I was home from school for spring break. This project is primarily for my own education with designing/fabricating composite parts, and I'm quite happy with how the skins came out. The look is a bit different than the stock RV-8 rudder, with some influences from the GB1 Gamebird.
I'll try to include some pictures on here, but I have a lot more pictures and a fairly detailed write up on my website: https://sites.google.com/view/adamav...der?authuser=0
Let me know what you think!
Adam Thomason
Aerospace Engineer
Old 03-17-2019, 04:40 PM
Dustyone Dustyone is offline
Default Awesome project
Hi Adam,
What a great project to learn about design and manufacturing .
Liked the new shape of the trailing edge.
Great write up on your website.
Ashley Miller
RV-10 #40597
Dual SDS CPI
http://www.vansairforce.com/communit...d.php?t=140051
Airflow Systems Air-Con
VH-XTE 800hrs +
Redcliffe,Brisbane
Australia
Photos : https://goo.gl/photos/zsfBeVofHMe4ze7i7
Old 03-17-2019, 05:40 PM
Mark33's Avatar
Mark33 Mark33 is offline
Wow...that looks really nice!! I?m sure you could sell a lot of those if you ever decided to produce them.
Old 03-17-2019, 06:27 PM
Don't forget to flutter-qualify it!
And since the area looks reduced, be sure to run it through the full set of lateral-directional stability and control tests.
Dave
Old 03-17-2019, 06:57 PM
Ashley and Mark: Glad you guys like it. The mold is still in great condition due to many hours or prep time.. additional rudders may be something I would consider a bit in the future, but this one is for education and validation.
Dave: The area of the rudder is nearly identical to the stock RV-8 rudder. The rudder will be counter-balanced as well. When it comes time, flight test will be taken seriously. Thanks for your concern!
Adam Thomason
Aerospace Engineer
Old 03-17-2019, 07:29 PM
BillL BillL is offline
Nice!! Are you going to bond real ribs in there for stiffness? Any projection on a weight comparison with the stock 8 rudder?
Bill
RV-7
Old 03-17-2019, 07:36 PM
Bill, a spar and ribs (all carbon fiber) will be bonded into the structure. I do not have a precise weight estimate yet, but it will not be any heavier than the stock rudder. I am using fairly high factors of safety and over-engineering it a bit, so it will not be quite as light as it could be.
Adam Thomason
Aerospace Engineer
Old 03-17-2019, 07:53 PM
N941WR's Avatar
N941WR N941WR is offline
That looks cool!
My only comment is that there isn't a fitting for the rear light.
Can you make the entire trailing edge a combination position and strobe light with LED's?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-17-2019, 07:56 PM
How does the torsional stiffness compare to the stock one?
Dave
Old 03-17-2019, 09:29 PM
dmattmul dmattmul is offline
Default Boiler Up !!
Knew he must be a Purdue student !!!!
RV-14A QB building, Lycoming 390 Thunderbolt arrived July 2019, Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 300-72, Parts became a real airplane 8/15/2020.
Started RV-10 Nov 2020. Empennage arrived (Built) Working on QB kits. Garmin avionics, Vertical Power, EFII-32 Ignition and Fuel, Whirlwind 3 blade, real airplane hopefully early 2023.
