Old 04-14-2007, 11:54 PM
N941WR's Avatar
N941WR N941WR is offline
Default How did you label your tip-up latch?
It appears the FAA would like me to label the canopy latch mechanism in my tip-up.
I was wondering how the rest of you labeled yours and did you label both latches?
I'm only worried about the inside label, not the outside.
Thanks for the help.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-15-2007, 01:12 AM
gvgoff99's Avatar
gvgoff99 gvgoff99 is offline
Default No Label
I did not label mine and no mention of such a label ever came up in the inspection. Some of the guys that have Air Force paint schemes have "emergency release" or similar painted on the outside. But in looking at Doug Reeves' "Flash" http://www.vansairforce.net/virtual_tour_n617ar.htm I don't see any on his. One of the pictures shows his interior latch too and it appears to be unlabeled. There are several Pictures of planes in the model specific area so you may want to surf that area for ideas. I have never seen a Cessna with "Door Latch" emblazoned on the area of the door latch (or maybe I never noticed ) You could label the pull out handle with a stick on label that has an arrow and note saying "Open" and point the arrow in the direction of movement when the handle opens. Once inspected sometimes these things fall off (unintentionally of course)
George Goff RV-6A (Flying 3/7/2006 )(Houston, TX)
Old 04-15-2007, 07:46 AM
Larco's Avatar
Larco Larco is offline
Default Latch Label
Cannot remember seeing a label on a latch on any tip up in the last 10 years of lurking. Mine is not labeled. Larry
Old 04-15-2007, 09:11 AM
N941WR's Avatar
Default No label is good news
Thanks guys.
I couldn't figure out how to label that latch so it would be understandable.
After labeling the Carb and Cabin Heat this morning I've put the label making stuff away and with luck, I won't need it again.
Bill R.
SC86 - Easley, SC
Old 04-15-2007, 05:52 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default DAR said label outside
My DAR wanted me to label the outside of the latch for the TU canopy because if I passed out from the heat or whatever, I could be rescued. I dutifully put on three labels because that's what it seemed to take to explain it. Then I realized that if the top safety catch is turned to "safe" all the rest is useless. I am considering putting a little handle for that on the outside the way it is on the slider, but haven't done it yet. Food for thought.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
