Old 04-14-2007, 11:27 PM
tx_jayhawk tx_jayhawk is offline
Default Manifold Pressure Fitting
Can anyone tell me if the attached VA-128 restrictor fitting installed on the #3 cylinder (used for manifold pressure) will interfere with the baffles? The instructions state to use a straight fitting, but I was planning to use this instead.
Have others not used a restrictor fitting for MAP? For fuel and oil you obviously have to, but I wonder if it is really necessary on MAP. I've been told the engine would run a lot rougher if a normal fitting was used instead of a restrictor (and the hose or something came off). Maybe I should install a staight aluminum fitting instead (AN816)?
Scott
7A Finishing
Old 04-15-2007, 01:56 AM
Paul Eastham's Avatar
Paul Eastham Paul Eastham is offline
I used a straight restrictor (from Wicks, I think.) There was some discussion a while back of some MAP instruments not reading correctly if a restrictor is not used.
The straight restrictor just barely clears the baffles. It would seem to me that the angled fitting is no different, but I can't say for sure.
Paul Eastham - Mountain View CA
RV-9A standard build, flying! ~300 hrs
EAA Chapter 338 San Jose
Old 04-15-2007, 10:53 AM
RV_7A RV_7A is offline
Scott 2 reasons for using the restrictor is to get a smoother signal at the sensor and if this hose cracks or breaks, you wont get bad lean condition on #3 and would most likely not even notice any change in the engines smoothness. Just makes good sense to use one due to the benefits. You can use a 45 there it just needs to point downward somewhat.
-Jeff
www.JeffsRV-7A.com
N808TX
