  #11
Old 03-16-2019, 12:28 PM
UnPossible's Avatar
UnPossible UnPossible is offline
Well it turns out I had two problems... one of my making and the other it looks like a design issue.
I did have the side flanges riveted on backwards. I have fixed that, but even with them now in the correct orientation, the brake pedals don't line up when the rudder bars are aligned due to the overhead rudder tubes being offset. (see below)
My plan is to order material to make new side flanges for at least two of the pedals. I'll clamp the rudder bars in alignment, then clamp the brake pedals in alignment, then finally drill the holes for the master cylinder to attach. This is what I did for my 7A, and everything aligns great.
I understand Van's desire to limit parts count (thus only making one part with the holes already drilled), but it seems like this would be a pretty easy fix from the factory to allow everything to line up.
Jason
Jason Tremble
RV-7A (Flying and Sold)
RV-10 in process (@#$$%# Cabin Top & Doors)
Paid for 2020
Old 03-16-2019, 12:44 PM
lr172 lr172 is offline
Jason
It seems apparent from the pic that the attachments are different (angle from main rudder support is obviously different). If you swapped left for right in the picture, you wouild have good alignment. I am sure if you read the plans again, that two different part numbers are called out for these attachments.
Old 03-16-2019, 01:06 PM
UnPossible's Avatar
Maybe I am wrong, but it sure doesn't look like there are two different side flanges. Best I can tell, you get 4 of the F-1052B's with the holes all ready pre-drilled (which is causing the alignment issue)
Jason Tremble
Paid for 2020
Old 03-16-2019, 01:09 PM
az_gila's Avatar
az_gila az_gila is offline
Smile
I had the same problem in the kit I bought
Easily fixed, just swap the fore and aft "crossbars"....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 03-16-2019, 01:25 PM
rocketman1988 rocketman1988 is offline
Default WD-1006 Torque tubes
Are you certain that the WD-1006 Rudder Torque Tubes are located properly?
There is a WD-1006-R and a WD-1006-L...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 03-16-2019, 01:35 PM
If you look at the plans, the crossbar with the far left pedal needs to be aft, not forward.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-16-2019, 06:08 PM
UnPossible's Avatar
OK - I am an idiot....... if there was a way to screw up the rudder/ brake pedals, I found the way to do it! Thanks for your suggestions.... all is good now.
Jason
Jason Tremble
Paid for 2020
Old 03-16-2019, 06:18 PM
wirejock's Avatar
wirejock wirejock is offline
Default Flanges
I see it now!
Told ya I was missing it.
Do 10 builders substitute the one long bolt through both sides of each brake like many other do?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 03-16-2019, 11:29 PM
I see that this approach works and is correct. However, you will notice that the plans have different pedals for L and R, so there are different parts, just not the ones that I guessed. However, if the OP followed my advise and didn't get yours, he would struggle with linkage issues, as the cable connection tab would be too far aft.
Good catch.
Larry
Old 03-16-2019, 11:33 PM
Originally Posted by wirejock View Post
I see it now!
pedal assembly is fundamentally the same as the others. I know that I used a single long bolt for better rigidity. I also added helper springs for the master cylinders.
Larry
